Author: wmb Date: 2010-01-26 08:15:41 +0100 (Tue, 26 Jan 2010) New Revision: 1702
Added: cpu/x86/bootascall.fth Log: Checked in bootascall.fth
Added: cpu/x86/bootascall.fth =================================================================== --- cpu/x86/bootascall.fth (rev 0) +++ cpu/x86/bootascall.fth 2010-01-26 07:15:41 UTC (rev 1702) @@ -0,0 +1,121 @@ +\ See license at end of file +purpose: Return from "booted" programs as if they were Forth words + +variable rp-var +variable sp-var +rs-size buffer: rs-buf +ps-size buffer: ps-buf + +code save-forth-state ( -- ) + cld + \ Copy the entire Forth data stack and return stack areas to a save area. + + si bx mov \ Save SI + di dx mov \ Save UP + + \ Data Stack + esp 'user sp-var mov + + 'user sp0 si mov + 'user ps-buf di mov \ Address of data stack save area + ps-size # si sub \ Bottom of data stack area (in longwords) + + ps-size 4 / # cx mov \ Size of data stack area + rep movs + + dx di mov \ Restore DI + + \ Return Stack + + ebp 'user rp-var mov + + 'user rp0 si mov + 'user rs-buf di mov \ Address of return stack save area + rs-size # si sub \ Bottom of return stack area + + rs-size 4 / # cx mov \ Size of return stack area (in longwords) + rep movs + + dx di mov \ Restore DI + + bx si mov \ Restore SI +c; + +: undo-boot-return ( -- ) + ['] (quit) to user-interface +; + +code resume-forth-state ( -- ) + cli cld + + di dx mov \ Save UP + + \ Copy the entire Forth data stack and return stack areas to a save area. + + \ Data Stack (load si first because di is the user pointer!) + 'user sp-var esp mov \ Data stack pointer + + 'user ps-buf si mov \ Address of data stack save area + 'user sp0 di mov \ Top of data stack areas + ps-size # di sub \ Bottom of data stack area (in longwords) + + ps-size 4 / # cx mov \ Size of data stack area + rep movs + + dx di mov \ Restore UP + + \ Return Stack (load si first because di is the user pointer!) + + 'user rp-var ebp mov \ Return stack pointer + + 'user rs-buf si mov \ Address of return stack save area + 'user rp0 di mov \ Top of return stack area + rs-size # di sub \ Bottom of return stack area + + rs-size 4 / # cx mov \ Size of return stack area (in longwords) + rep movs + + dx di mov \ Restore UP + sti + + 0 [ebp] esi mov \ Pop the return stack into the interpreter pointer + 4 # ebp add +c; + +0 value saved-go-hook +: boot-as-call( ( -- ) + ps-buf drop rs-buf drop + ['] go-hook behavior to saved-go-hook + ['] save-forth-state to go-hook + ['] resume-forth-state to user-interface +; +: )boot-as-call ( -- ) + saved-go-hook to go-hook + ['] (quit) to user-interface +; +ps-buf drop rs-buf drop +: foo boot-as-call( emacs )boot-as-call cr ." Hello" cr ; + +\ LICENSE_BEGIN +\ Copyright (c) 2010 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
