Author: quozl Date: Fri Nov 16 02:17:56 2012 New Revision: 3437 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3437
Log: OLPC XO-4 - new touchscreen firmware 0.0.0.8 with four finger support, slight compensating changes to timing of deactivate, avoid expecting boot complete message unless a reset is done.
Modified: cpu/arm/olpc/4.0/nn-version.fth cpu/arm/olpc/nn-touchscreen.fth cpu/arm/olpc/nnflash.fth
Modified: cpu/arm/olpc/4.0/nn-version.fth ============================================================================== --- cpu/arm/olpc/4.0/nn-version.fth Thu Nov 15 23:25:41 2012 (r3436) +++ cpu/arm/olpc/4.0/nn-version.fth Fri Nov 16 02:17:56 2012 (r3437) @@ -1,2 +1,2 @@ \ The Neonode touchscreen firmware -macro: NN_VERSION 0_0_0_7 +macro: NN_VERSION 0_0_0_8
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Thu Nov 15 23:25:41 2012 (r3436) +++ cpu/arm/olpc/nn-touchscreen.fth Fri Nov 16 02:17:56 2012 (r3437) @@ -108,6 +108,9 @@ 2drop ( ) ;
+: flush-input ( -- ) + 0 0 anticipate +;
: read-boot-complete ( -- ) @@ -135,7 +138,7 @@ : start ( -- ) h# 04 h# 01 h# ee 3 bytes-out ;
: deactivate ( -- ) - h# 00 h# 01 h# ee 3 bytes-out h# 00 d# 20 anticipate + h# 00 h# 01 h# ee 3 bytes-out h# 00 d# 60 anticipate ;
: deconfigure ( -- ) @@ -164,11 +167,13 @@ ." no response to reset" cr pbuf-free false exit then - then - ['] read-boot-complete catch ?dup if - .error - ." failed to boot" cr - pbuf-free false exit + ['] read-boot-complete catch ?dup if + .error + ." failed to boot" cr + pbuf-free false exit + then + else + flush-input then ['] configure catch ?dup if .error
Modified: cpu/arm/olpc/nnflash.fth ============================================================================== --- cpu/arm/olpc/nnflash.fth Thu Nov 15 23:25:41 2012 (r3436) +++ cpu/arm/olpc/nnflash.fth Fri Nov 16 02:17:56 2012 (r3437) @@ -54,7 +54,7 @@ : update-nn-flash? ( -- flag ) \ XO-4 B1 have clear lightguides incompatible with later versions \ of touchscreen firmware. - \ (disabled temporarily so that automatic update can be tested) + \ (disabled temporarily so that automatic update can be tested) \ board-revision h# 4b20 < if false exit then nn-image$ nn-up-to-date? 0= ;
