Author: wmb Date: 2008-07-30 00:09:17 +0200 (Wed, 30 Jul 2008) New Revision: 861
Modified: dev/mmc/sdhci/sdhci.fth Log: OLPC trac 7702 - Fixed random hang when reading SD cards > 4 GB. The problem was an off-by-one error in the CSD parser, which caused it to look at an undefined bit outside the CSD area, sometimes causing the wrong card size to be reported.
Modified: dev/mmc/sdhci/sdhci.fth =================================================================== --- dev/mmc/sdhci/sdhci.fth 2008-07-29 00:57:21 UTC (rev 860) +++ dev/mmc/sdhci/sdhci.fth 2008-07-29 22:09:17 UTC (rev 861) @@ -596,6 +596,7 @@ : dma-free ( vadr size -- ) " dma-free" $call-parent ;
: r/w-blocks ( addr block# #blocks in? -- actual ) + over 0= if 2drop 2drop 0 exit then \ Prevents hangs intstat-on >r ( addr block# #blocks r: in? ) rot dma-setup ( block# r: in? ) @@ -655,7 +656,7 @@ \ The calculation below is shown on page 81 of the \ SD Physical Layer Simplified Specification Version 2.00. : size ( -- d.bytes ) - d# 128 d# 126 csdbits case + d# 127 d# 126 csdbits case 0 of d# 49 d# 47 csdbits ( c_size_mult ) 2 + 1 swap lshift ( mult ) @@ -670,7 +671,8 @@ d# 70 d# 48 csdbits d# 10 lshift h# 200 um* endof ( default ) - h# ffffffff 0 rot + ." SD: Warning - invalid CSD; using default device size." cr + h# 8.0000.0000. rot \ 32 GB endcase ; external
