Author: quozl Date: Wed Aug 29 07:49:44 2012 New Revision: 3242 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3242
Log: OLPC XO-4 - Neonode, rework test coverage based on new requirements, vendor recommends forced LED levels test
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Wed Aug 29 07:04:41 2012 (r3241) +++ cpu/arm/olpc/nn-touchscreen.fth Wed Aug 29 07:49:44 2012 (r3242) @@ -4,6 +4,17 @@ 0 0 " 4,50" " /twsi" begin-package my-space encode-int my-address encode-int encode+ " reg" property
+create nn-os \ open short test +create nn-fll \ forced led levels test +create nn-version \ version display + +\ create nn-fss \ optional fixed signal strength test +\ create nn-ls \ optional low signals test + +\ create nn-components \ isolate test results to failed component identifier + +\ create nn-ir-pcb-rev-b \ support for revision b of the ir pcb assembly + \ XXX these are really platform-related, not touchscreen-related : targets? ( -- flag ) final-test? ; : .tsmsg ( -- ) 0 d# 27 at-xy ." Touchscreen test. Type a key to exit" cr ; @@ -65,6 +76,8 @@ 2drop ( ) ;
+ + : read-boot-complete ( -- ) h# 07 d# 0 anticipate ;
: initialise ( -- ) h# 01 h# 01 h# ee 3 twsi-out h# 01 d# 20 anticipate ; @@ -132,6 +145,17 @@ ;
+ +0 value faults +: fault faults 1+ to faults ; + +: 4sp ." " ; + +: 8sp ." " ; + + + +[ifdef] nn-version \ version display : (.version) ( addr -- ) dup c@ over 1+ c@ bwjoin ( addr version ) (.) type @@ -154,14 +178,11 @@ .version cr ; +[then]
-0 value faults -: fault faults 1+ to faults ;
-: 4sp ." " ; - -: 8sp ." " ; +[ifdef] nn-os \ open short test
[ifdef] nn-components \ optional decoding of component identifiers @@ -352,6 +373,11 @@ 4sp ." X Axis" cr 0 test-os-axis 4sp ." Y Axis" cr 1 test-os-axis ; +[then] + + + +[ifdef] nn-fss \ fixed signal strength test
[ifdef] nn-components d# 11 constant x-ir-0 \ first X axis IR component identifier @@ -383,8 +409,6 @@ \ Y axis, IR11 PD12, IR11 PD11, IR10 PD11 ... IR1 PD1 \ X axis, IR12 PD13, IR12 PD14, IR13 PD14 ... IR26 PD28 [then] - \ FIXME: using a light guide, characterise a low signal level, - \ detect, and fail self test ;
: test-fss @@ -392,6 +416,9 @@ 4sp ." X Axis" cr 0 test-fss-axis 4sp ." Y Axis" cr 1 test-fss-axis ; +[then] + +
[ifdef] nn-ls \ low signals test : test-ls-axis ( axis -- ) @@ -424,6 +451,8 @@ ; [then]
+ + [ifdef] nn-fll \ forced LED levels test : test-fll-signal ( signal# signal-value led-level -- ) dup 0= if @@ -442,7 +471,11 @@ cr exit then - 2drop ." pass on axis signal " .d cr + \ 2drop ." pass on axis signal " .d cr + 3drop +[ifdef] nn-components + \ FIXME: express forced led levels faults in terms of IR PCB component names. +[then] ;
: test-fll-axis ( axis -- ) @@ -464,6 +497,8 @@ ; [then]
+ + : press ( line$ -- ) type ." , press a key" @@ -474,41 +509,64 @@ : connect " Connect IR PCB" press ; : disconnect " Disconnect IR PCB" press ;
+: dump-events + begin + in? if + ." rx: " pbuf plen bounds do + i c@ 2u.x space + loop cr + then + key? + until + key drop +; + : selftest ( -- error? )
- smt-test? if + 0 to faults + + test-station h# 1 = test-station h# 11 = or if \ IR PCB SMT and MB SMT hold-reset connect - 0 to faults open if test-os else fault then hold-reset disconnect faults exit then
+ test-station h# 12 = if \ IR PCB ASSY + hold-reset connect + open if test-fll else fault then + hold-reset disconnect + faults exit + then +[ifdef] nn-ir-pcb-rev-b + test-station h# 2 = if \ MB ASSY + open if test-finger-down-each-edge else fault then + faults exit + then +[then] + + \ MB FINAL + \ MB SHIP open 0= if ." No touchscreen present" cr false exit then
diagnostic-mode? if 0 to faults - test-version - test-os - test-fss + [ifdef] nn-version test-version [then] + [ifdef] nn-os test-os [then] + [ifdef] nn-fss test-fss [then] + [ifdef] nn-fll test-fll [then] faults if close true exit then then
- ." dumping events from touchscreen controller, press a key to stop" cr - +[ifdef] nn-ir-pcb-rev-b \ FIXME: graphically show data on screen until key \ ... waiting for revision B of IR PCB - begin - in? if - ." rx: " pbuf plen bounds do - i c@ 2u.x space - loop cr - then - key? - until - key drop +[else] + ." dumping events from touchscreen controller, press a key to stop" cr + dump-events +[then]
close false ;
