Author: wmb Date: 2009-06-07 07:00:39 +0200 (Sun, 07 Jun 2009) New Revision: 1217
Added: cpu/x86/pc/olpc/via/resume.bth cpu/x86/pc/olpc/via/suspend.fth Modified: cpu/x86/pc/olpc/via/demodram.fth cpu/x86/pc/olpc/via/fw.bth cpu/x86/pc/olpc/via/olpc.bth cpu/x86/pc/olpc/via/romreset.bth cpu/x86/pc/olpc/via/starthostctl.fth cpu/x86/pc/olpc/via/versions.fth Log: Via - S3 from OFW is sort of working, from the serial console.
Modified: cpu/x86/pc/olpc/via/demodram.fth =================================================================== --- cpu/x86/pc/olpc/via/demodram.fth 2009-06-06 08:21:47 UTC (rev 1216) +++ cpu/x86/pc/olpc/via/demodram.fth 2009-06-07 05:00:39 UTC (rev 1217) @@ -76,35 +76,6 @@ [then] end-table
-\ DRDR_BL.c -\ DRAMDRDYsetting - 0 2 devfunc -[ifdef] demo-board - 60 ff aa mreg \ DRDY Timing Control 1 for Read Line - 61 ff 0a mreg \ DRDY Timing Control 2 for Read Line - 62 ff 00 mreg \ Reserved, probably channel B - 63 ff aa mreg \ DRDY Timing Control 1 for Read QW - 64 ff 0a mreg \ DRDY Timing Control 2 for Read QW - 65 ff 00 mreg \ Reserved, probably channel B - 66 ff 00 mreg \ Burst DRDR Timing Control for Second cycle in burst - 67 ff 00 mreg \ Reserved, probably channel B - 54 0a 08 mreg \ Misc ctl 1 - special mode for DRAM cycles - 51 80 80 mreg \ Last step - enable DRDY timing -[then] -[ifdef] xo-board - 60 ff 2a mreg \ DRDY Timing Control 1 for Read Line - 61 ff 00 mreg \ DRDY Timing Control 2 for Read Line - 62 ff 00 mreg \ Reserved, probably channel B - 63 ff 15 mreg \ DRDY Timing Control 1 for Read QW - 64 ff 00 mreg \ DRDY Timing Control 2 for Read QW - 65 ff 00 mreg \ Reserved, probably channel B - 66 ff 00 mreg \ Burst DRDR Timing Control for Second cycle in burst - 67 ff 00 mreg \ Reserved, probably channel B - 54 1e 1c mreg \ Misc ctl 1 - special mode for DRAM cycles - 51 ff f8 mreg \ Last step - enable DRDY timing -[then] - end-table - \ DRAMBurstLength 0 3 devfunc 6c 08 08 mreg \ Burst length 8
Modified: cpu/x86/pc/olpc/via/fw.bth =================================================================== --- cpu/x86/pc/olpc/via/fw.bth 2009-06-06 08:21:47 UTC (rev 1216) +++ cpu/x86/pc/olpc/via/fw.bth 2009-06-07 05:00:39 UTC (rev 1217) @@ -329,8 +329,8 @@
fload ${BP}/cpu/x86/pc/olpc/help.fth fload ${BP}/cpu/x86/pc/olpc/gui.fth -fload ${BP}/cpu/x86/pc/olpc/suspend.fth \ Suspend/resume setup [then] +fload ${BP}/cpu/x86/pc/olpc/via/suspend.fth \ Suspend/resume setup fload ${BP}/dev/olpc/keyboard/selftest.fth \ Keyboard diagnostic fload ${BP}/dev/olpc/touchpad/touchpad.fth \ Touchpad diagnostic [ifdef] Later @@ -709,8 +709,8 @@ ;
: sci-wakeup ( -- ) ; -: acpi-l@ ( index -- l ) drop 0 ; -: acpi-l! ( l index -- ) 2drop ; +\ : acpi-l@ ( index -- l ) drop 0 ; +\ : acpi-l! ( l index -- ) 2drop ; : s3 ( -- ) ;
Modified: cpu/x86/pc/olpc/via/olpc.bth =================================================================== --- cpu/x86/pc/olpc/via/olpc.bth 2009-06-06 08:21:47 UTC (rev 1216) +++ cpu/x86/pc/olpc/via/olpc.bth 2009-06-07 05:00:39 UTC (rev 1217) @@ -71,9 +71,7 @@ " romreset.di" $add-file [then]
-[ifdef] Later " resume.di" $add-file -[then]
\ Loads the set of drivers that is common to different output formats
Added: cpu/x86/pc/olpc/via/resume.bth =================================================================== --- cpu/x86/pc/olpc/via/resume.bth (rev 0) +++ cpu/x86/pc/olpc/via/resume.bth 2009-06-07 05:00:39 UTC (rev 1217) @@ -0,0 +1,405 @@ +\ See license at end of file +purpose: Low-level code to handle suspend/resume from RAM + +command: &builder &this +build-now + +\needs start-assembling fload ${BP}/cpu/x86/asmtools.fth +\needs write-dropin fload ${BP}/forth/lib/mkdropin.fth + +\ create debug-startup + +hex + +\ fload ${BP}/cpu/x86/pc/report.fth \ Startup reports for debugging + +fload ${BP}/cpu/x86/pc/olpc/via/config.fth \ Configuration defines + +fload ${BP}/cpu/x86/startmacros.fth +fload ${BP}/cpu/x86/pc/port80.fth + +\ This code will be copied to RAM at suspend-base + +\ create measure-suspend +\ create save-display +\ create reset-smbus +\ create reset-smbus-bitbang +\ create restore-usb-power +\ create checksum-test + +: resume-progress ( byte -- ) + " h# 34 # al mov al h# 70 # out ( byte ) # al mov al h# 71 # out" eval +; + +start-assembling \ Turn on the target assembler +protected-mode + +\ Suspend code - called as a subroutine, with return address on the stack +\ This assumes that the following code is in an area that is mapped virtual=physical +\ The assumption is embodied by the fact that paging is turned off on the way +\ down, while continuing to execute straight-line code. Also, the BP register +\ is used as a memory pointer before and after the paging turn-off. + +label suspend-entry \ h# f.0000 - entry point at fixed location, called by OS + here h# 10 + #) jmp \ Jump to offset 10 + 8 pad-to + +label resume-entry \ h# f.0008 - entry point at fixed location, called by resume + e9 c, 0 , \ To be patched later + nop \ Aligns to even, for the benefit of the disassembler + h# 10 pad-to + +label suspend-save \ h# f.0010 (Page directory VA in ax) + pusha + pushf cli + ds push + es push + fs push + gs push + ss push dx pop \ SS in dx + + here 5 + dup #) call di pop \ Virtual address of EIP in DI + ( here ) asm-base - # di sub \ Virtual address of suspend-base in DI + + \ Page directory VA in AX + ax si mov \ Save PDIR VA + 0 [si] cx mov forget-msr \ Save old PDIR entry 0 + h# 83 # 0 [ax] mov \ Punch a 4M mapping 0->0 into the page directory + cr3 ax mov ax cr3 mov \ Invalide the TLB to activate the mapping + h# f0060 # ax mov ax jmp \ Jump to suspend-physical, disabling paging + h# 60 pad-to + + \ We have to be running from a virtual=physical mapping here, otherwise we + \ die on the instruction after paging is turned off. + cr0 ax mov ax bx mov \ CR0 saved in BX + h# 80000000 invert # ax and \ Knock off the Paging enable (PG) bit + ax cr0 mov \ Now paging is off + + \ Physical addresses from now on + +\ suspend-physical +\ here suspend-entry put-branch + resume-data # bp mov + +\ here 5 + dup #) call bp pop \ EIP (virtual) in AX +\ ( here ) asm-base - suspend-base + # bp sub +\ resume-data # bp add + + sp 0 [bp] mov \ SP part of SP:SS full pointer + op: dx 4 [bp] mov \ SS part of SP:SS full pointer + + h# 6 [bp] str \ Task register + h# 8 [bp] sldt \ Local descriptor table register + h# a [bp] sidt \ Interrupt descriptor table register + h# 10 [bp] sgdt \ Global descriptor table register + + bx h# 18 [bp] mov + cr3 ax mov ax h# 1c [bp] mov + cr4 ax mov ax h# 20 [bp] mov + cx h# 24 [bp] mov \ PDIR entry 0 + si h# 28 [bp] mov \ PDIR VA + di h# 2c [bp] mov \ Address offset + + cld + h# 38 [bp] di lea \ Save area + +[ifdef] measure-suspend + rdtsc eax h# 10 #) mov edx h# 14 #) mov +[then] + +\ This is where Geode saves msrs +\ This is where Geode handles the DCON +\ This is where Geode saves the GPIO setup +\ This is where Geode saves the display state +\ This is where Geode saves the PIC state (remember the edge/level registers) +\ This is where Geode saves the PIT state +\ This is where Geode saves the SMBUS controller state +\ This is where Geode saves the MFGPT state +\ This is where Geode saves the CaFe configuration + + \ Other state we might want to save: + \ ISA DMA Controller + \ AC97 + \ Codec + \ USB + +\ This is where Geode stops the video refresh + +[ifdef] checksum-test + \ Checksum memory from 1M to top (excluding framebuffer) + h# 0010.0000 # si mov + h# 4d534b43 # ax mov ax stos \ Marker 'CKSM' + di resume-data h# 10 - #) mov \ Save checksum base address + begin + bx bx xor + h# 10.0000 2 rshift # cx mov \ Word count for 1MB + begin ax lods ax bx add loopa + ax stos + h# ec0.0000 # si cmp + = until +[then] + +[ifdef] measure-suspend + di 0 #) mov + rdtsc ax h# 18 #) mov dx h# 1c #) mov +[then] + + \ This is where the Geode sets up the sleep/wakeup sequence timing + + \ Clear existing wakeup status + h# 400 port-rw ax dx out + + \ The caller chooses the wakeup conditions, so we don't do it here + h# ffff h# 420 port-wl \ Clear all status bits + + h# fe resume-progress + + wbinvd \ Flush the cache + + \ Setup the register values in advance so the active instruction sequence + \ is as short as possible, thus keeping all the activity in one cache line. + h# 0400 h# 404 port-ww \ Setup sleep type + + \ Align to a cache line boundary + also forth + begin here asm-base - h# 1f and while h# 90 c, repeat \ Align with NOPs + previous + + h# 2400 h# 404 port-ww \ Go to sleep + + h# fff # cx mov begin nop loopa \ Spin in this cache line while going down + + \ If the processor didn't really go down, perhaps because a wakeup event was + \ already pending, proceed as with a wakeup + + \ Increment the CMOS byte at offset 3f + h# 3f # al mov al h# 70 # out h# 71 # al in al inc al h# 71 # out + +\ Resume code +here resume-entry put-branch + +\ Assumptions: +\ Processor is in protected mode +\ Running from a 32-bit identity-mapped code segment +\ Using physical addresses + +\ char < 3f8 port-wb begin 3fd port-rb 20 bitand 0<> until + + resume-data # bp mov + + cld + + h# 20 resume-progress + +[ifdef] measure-suspend + rdtsc eax h# 20 #) mov edx h# 24 #) mov +[then] + + h# 21 resume-progress + +[ifdef] checksum-test + \ Checksum memory from 1M to top (excluding framebuffer) + h# 0010.0000 # si mov + resume-data h# 10 - #) di mov \ Save checksum base address + begin + bx bx xor + h# 10.0000 2 rshift # cx mov \ Word count for 1MB + begin ax lods ax bx add loopa + ax 0 [di] cmp + <> if + char C 3f8 port-wb begin 3fd port-rb 20 bitand 0<> until + ret + then + 4 [di] di lea + h# ec0.0000 # si cmp + = until +[then] + + h# 38 [bp] si lea \ Save area + + h# 22 resume-progress + +[ifdef] reset-smbus-bitbang + \ GPIO15 is SMB_DATA + \ GPIO14 is SMB_CLOCK + h# 5140.000c rmsr ax bx mov + h# c000 # ax mov \ Mask to set SMB_DATA and SMB_CLOCK + h# 00 [bx] dx lea ax dx out \ Set output values to high + h# 04 [bx] dx lea ax dx out \ Set pins to output + h# c0000000 # ax mov \ Mask to clear SMB_DATA and SMB_CLOCK + h# 10 [bx] dx lea ax dx out \ Deselect OUT AUX1 + h# 14 [bx] dx lea ax dx out \ Deselect OUT AUX2 + h# 34 [bx] dx lea ax dx out \ Deselect IN AUX1 + + d# 16 # cx mov forget-msr \ Generate 8 low pulses on SMB_CLOCK + begin + \ 5 uS delay (slightly longer for GX) + rdtsc ax bx mov d# 5 d# 500 * # bx add + begin rdtsc bx ax sub 0>= until + + cx bx mov \ Save cx for use by rmsr + h# 5140.000c rmsr ax dx mov \ GPIO output register + h# 40000000 # ax mov ax dx out \ Clear SMB_CLOCK + bx cx mov forget-ms \ Restore cx + + \ 5 uS delay (slightly longer for GX) + rdtsc ax bx mov d# 5 d# 500 * # bx add + begin rdtsc bx ax sub 0>= until + + cx bx mov \ Save cx for use by rmsr + h# 5140.000c rmsr ax dx mov \ GPIO output register + h# 4000 # ax mov ax dx out \ Set SMB_CLOCK + bx cx mov forget-msr \ Restore cx + loopa + + \ 5 uS delay (slightly longer for GX) + rdtsc ax bx mov d# 5 d# 500 * # bx add + begin rdtsc bx ax sub 0>= until +[then] + + h# 23 resume-progress + +\ GPIO restore + + h# 24 resume-progress + +\ Display restore + +\ Flat panel turn-on + + h# 25 resume-progress + +\ PIC restore + + h# 26 resume-progress + +\ PIT restore + + h# 27 resume-progress + +\ SMBUS controller restore + +[ifdef] reset-smbus + \ This little dance resets the DCON's SMbus interface + \ We start with dx pointing to SMBUS reg 5 + dx dec dx dec \ Point back to smbus reg3 (control 1) + h# 1 # al mov \ START + al dx out \ Initiate an SMBUS cycle to the DCON + + \ We could split here and move the following down, so as to overlap + \ the delay time with other work, but it doesn't matter because the + \ later CaFe chip setup will stall anyway. + + d# 32 # cx mov forget-msr \ Loop count (usually ready in 20 uS) + dx dec dx dec \ SMBUS reg1 (status) + begin + dx al in + h# 40 # al test + loope \ Wait for ready to accept byte or timeout + + h# 1a # al mov \ Address byte + dx dec \ SMBUS reg0 (data) + al dx out \ Initiate address out cycle + + \ Another possible split point, in case we should need to overlap + d# 256 # cx mov forget-msr \ Loop count (usually ready in 172 uS) + dx inc \ SMBUS reg1 (status) + begin + dx al in + h# 50 # al test + loope \ Wait for done or error or timeout + + h# 2 # al mov \ Stop + dx inc dx inc \ SMBUS reg3 (control 1) + al dx out \ Initiate STOP + + h# 10 # al mov \ Ack NEGACK + dx dec dx dec \ SMBUS reg1 (status) + al dx out \ While acking the NEGACK + \ End of DCON SMbus reset dance +[then] + + h# 28 resume-progress + +\ MFGPTs restore + + h# 29 resume-progress + + \ AC97 + \ Codec + + \ h# 8000 h# 4000.0000 or h# 1440 pl! \ Fail-safe delay + +\ Turn on USB power + + h# 2a resume-progress + +\ Restore CaFe configuration + + h# 2b resume-progress + +\ Display base addresses + + \ There is a lot of other stuff that must be done to turn on the + \ video - but we will let the gx driver take care of that. + + \ XXX keyboard init + \ DCON fiddling + \ USB + +[ifdef] measure-suspend + rdtsc eax h# 28 #) mov edx h# 2c #) mov + si 4 #) mov +[then] + + h# 2c resume-progress + + h# 2c [bp] di mov \ VA of suspend-base in di + h# 28 [bp] si mov \ PDIR VA + h# 24 [bp] cx mov forget-msr \ PDIR entry 0 + h# 20 [bp] ax mov ax cr4 mov + h# 1c [bp] ax mov ax cr3 mov + h# 18 [bp] ax mov + + h# 10 [bp] lgdt \ Global descriptor table register + h# a [bp] lidt \ Interrupt descriptor table register + h# 8 [bp] lldt \ Local descriptor table register + op: h# ffff # h# 6 [bp] test 0<> if +\ h# 6 [bp] ltr \ Task register + then + + ax cr0 mov \ Paging is back on now (if it ever was on) + + \ Force the paging enable to take place + h# eb asm8, 0 asm8, \ jmp to next location to enable paging + + h# 2d resume-progress + + \ Now jump back to the virtual execution address + here asm-base - 8 + # di add \ The add instruction is 6 bytes, the jmp is 2 + di jmp + + \ Identity mapping of low memory is still in effect + 0 [bp] sp lss + + cx 0 [si] mov \ Restore PDIR entry 0 + cr3 ax mov ax cr3 mov \ Flush TLB + + \ Identity mapping of low memory might not exist now + +\ char > 3f8 port-wb begin 3fd port-rb 20 bitand 0<> until + + gs pop + + fs pop + es pop + ds pop + popf + popa + ret +end-code + + +writing resume.di +suspend-entry here over - 0 " resume" write-dropin +ofd @ fclose
Modified: cpu/x86/pc/olpc/via/romreset.bth =================================================================== --- cpu/x86/pc/olpc/via/romreset.bth 2009-06-06 08:21:47 UTC (rev 1216) +++ cpu/x86/pc/olpc/via/romreset.bth 2009-06-07 05:00:39 UTC (rev 1217) @@ -107,27 +107,35 @@
carret report linefeed report - char F report + char + report h# 1d port80
\ This is a device ID backdoor to fake out the ID so Ubuntu will install \ 8879 config-rb h# 40 # al or al dx out \ I don't know what this is, but coreboot does it
-1 [if] - \ This turns an OS reboot into a real cold start - from coreboot + fload ${BP}/cpu/x86/pc/olpc/via/starthostctl.fth + + long-offsets on + acpi-io-base 1 + 8888 config-ww \ Set ACPI base address 8c 8881 config-wb \ Enable ACPI regs, 32-bit PM timer, guard RTC against power glitches acpi-io-base 4 + port-rw \ Get APCI Status register - d# 10 # ax shr 7 # ax and 1 # ax cmp <> if \ Not a wakeup from S3 + d# 10 # ax shr 7 # ax and 1 # ax cmp = if \ Wakeup from S3 + char r report + resume-data # sp mov + resume-entry # ax mov ax call \ This might return if checksumming fails + char x report + else \ Not a wakeup from S3 + \ This turns an OS reboot into a real cold start - from coreboot 380 config-rb ax ax or 0<> if \ C-page shadowing not on yet 6 cf9 port-wb \ Force a full system reset + char X report + begin hlt again then + char F report + fload ${BP}/cpu/x86/pc/olpc/via/demodram.fth then -[then]
- fload ${BP}/cpu/x86/pc/olpc/via/starthostctl.fth - fload ${BP}/cpu/x86/pc/olpc/via/demodram.fth - fload ${BP}/cpu/x86/pc/olpc/via/startgfxinit.fth
0 [if] \ Fire up C Forth
Modified: cpu/x86/pc/olpc/via/starthostctl.fth =================================================================== --- cpu/x86/pc/olpc/via/starthostctl.fth 2009-06-06 08:21:47 UTC (rev 1216) +++ cpu/x86/pc/olpc/via/starthostctl.fth 2009-06-07 05:00:39 UTC (rev 1217) @@ -37,3 +37,32 @@ 99 0e 06 mreg \ CPU Misc Ctrl 97 ff 00 mreg \ APIC Related Control end-table + +\ DRDR_BL.c +\ DRAMDRDYsetting + 0 2 devfunc +[ifdef] demo-board + 60 ff aa mreg \ DRDY Timing Control 1 for Read Line + 61 ff 0a mreg \ DRDY Timing Control 2 for Read Line + 62 ff 00 mreg \ Reserved, probably channel B + 63 ff aa mreg \ DRDY Timing Control 1 for Read QW + 64 ff 0a mreg \ DRDY Timing Control 2 for Read QW + 65 ff 00 mreg \ Reserved, probably channel B + 66 ff 00 mreg \ Burst DRDR Timing Control for Second cycle in burst + 67 ff 00 mreg \ Reserved, probably channel B + 54 0a 08 mreg \ Misc ctl 1 - special mode for DRAM cycles + 51 80 80 mreg \ Last step - enable DRDY timing +[then] +[ifdef] xo-board + 60 ff 2a mreg \ DRDY Timing Control 1 for Read Line + 61 ff 00 mreg \ DRDY Timing Control 2 for Read Line + 62 ff 00 mreg \ Reserved, probably channel B + 63 ff 15 mreg \ DRDY Timing Control 1 for Read QW + 64 ff 00 mreg \ DRDY Timing Control 2 for Read QW + 65 ff 00 mreg \ Reserved, probably channel B + 66 ff 00 mreg \ Burst DRDR Timing Control for Second cycle in burst + 67 ff 00 mreg \ Reserved, probably channel B + 54 1e 1c mreg \ Misc ctl 1 - special mode for DRAM cycles + 51 ff f8 mreg \ Last step - enable DRDY timing +[then] + end-table
Added: cpu/x86/pc/olpc/via/suspend.fth =================================================================== --- cpu/x86/pc/olpc/via/suspend.fth (rev 0) +++ cpu/x86/pc/olpc/via/suspend.fth 2009-06-07 05:00:39 UTC (rev 1217) @@ -0,0 +1,76 @@ +purpose: Setup and tests for suspend/resume to RAM +\ See license at end of file + +stand-init: Suspend/resume + " resume" find-drop-in if + suspend-base swap move + then +; + +\ Useful for debugging suspend/resume problems +\ : sum-forth ( -- ) 0 here origin do i c@ + loop . cr ; + +code ax-call ( ax-value dst -- ) bx pop ax pop bx call c; + +.( XXX Implement lid-wakeup) cr +: lid-wakeup +; + +.( XXX Implement sci-wakeup) cr +: sci-wakeup +; + +: s3 + \ Enable wakeup from power button, also clearing + \ any status bits in the low half of the register. + 0 acpi-l@ h# 100.0000 or 0 acpi-l! + + h# ffff h# 20 acpi-w! \ Clear PME status bits +\ XXX may need to clear other status bits elsewhere as well + +\ sum-forth +[ifdef] virtual-mode + [ also dev /mmu ] pdir-va h# f0000 ax-call [ previous definitions ] +[else] + sp@ 4 - h# f0000 ax-call \ sp@ 4 - is a dummy pdir-va location +[then] +\ sum-forth +; +: kb-suspend ( -- ) + sci-wakeup + begin + begin 1 ms key? while key dup [char] q = abort" Quit" emit repeat + s3 + again +; +: suspend +\ " video-save" screen-ih $call-method \ Freeze display + s3 +\ " video-restore" screen-ih $call-method \ Unfreeze display +\ " /usb@f,5" open-dev ?dup if " do-resume" 2 pick $call-method close-dev then +; +alias s suspend + +\ LICENSE_BEGIN +\ Copyright (c) 2007 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Modified: cpu/x86/pc/olpc/via/versions.fth =================================================================== --- cpu/x86/pc/olpc/via/versions.fth 2009-06-06 08:21:47 UTC (rev 1216) +++ cpu/x86/pc/olpc/via/versions.fth 2009-06-07 05:00:39 UTC (rev 1217) @@ -2,7 +2,7 @@
\ The overall firmware revision macro: FW_MAJOR A -macro: FW_MINOR 03j +macro: FW_MINOR 03k
\ The EC microcode macro: EC_VERSION 1_9_1
