Author: wmb Date: Fri Jul 27 04:55:18 2012 New Revision: 3086 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3086
Log: OLPC SPIFLASH driver - handle 2 MB parts.
Modified: dev/olpc/spiflash/spiflash.fth
Modified: dev/olpc/spiflash/spiflash.fth ============================================================================== --- dev/olpc/spiflash/spiflash.fth Fri Jul 27 04:54:42 2012 (r3085) +++ dev/olpc/spiflash/spiflash.fth Fri Jul 27 04:55:18 2012 (r3086) @@ -199,6 +199,8 @@ 3drop ;
+: null-write ( adr len offset -- ) 3drop ; + \ This version is for SST parts, which use an auto-increment \ address command for fast writing. The SST part does not \ require you to stop at 256-byte page boundaries. The @@ -306,12 +308,16 @@ h# 13 of ['] common-write endof h# 34 of ['] common-write endof h# bf of ['] sst-write endof - h# 14 of - ." The SPI FLASH ID reads as 14. This is due to an infrequent hardware problem." cr - ." If you power cycle and try again, it will probably work the next time." cr - abort - endof - ( default ) true abort" Unsupported SPI FLASH ID" + h# 14 of ['] common-write endof +\ On some old board the ID would read as 14 when it should have been something else. +\ On CL4, 14 is the expected ID. +\ ." The SPI FLASH ID reads as 14. This is due to an infrequent hardware problem." cr +\ ." If you power cycle and try again, it will probably work the next time." cr +\ abort +\ endof + +\ ( default ) true abort" Unsupported SPI FLASH ID" + ( default ) ." Bad SPI FLASH ID " dup . cr ['] null-write swap endcase to write-spi-flash spi-unprotect @@ -326,6 +332,7 @@ else spi-id# case h# 13 of ." type 13 - Spansion, Winbond, or ST" endof + h# 14 of ." type 14 - 2 MB" endof h# 34 of ." type 34 - Macronyx" endof endcase then
