Author: quozl Date: Tue Apr 2 04:46:16 2013 New Revision: 3633 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3633
Log: OLPC - libertas, reduce the scan time to 30ms per channel for an active scan, and raise it to 110ms per channel for a passive scan, based on a kernel patch provided by Marvell.
Modified: dev/libertas.fth
Modified: dev/libertas.fth ============================================================================== --- dev/libertas.fth Thu Mar 28 12:34:12 2013 (r3632) +++ dev/libertas.fth Tue Apr 2 04:46:16 2013 (r3633) @@ -1166,9 +1166,10 @@ dup channel-is-5ghz? if 1 else 0 then ( channel# band# ) +xb \ Band # +xb \ Channel # - scan-type +xb \ Scan type - 0:active or 1:passive - d# 100 +xw \ Min scan time - d# 100 +xw \ Max scan time ( r: payload' ) + scan-type dup +xb \ Scan type - 0:active or 1:passive + if d# 30 else d# 110 then + dup +xw \ Min scan time + +xw \ Max scan time ( r: payload' ) 'x r@ - r> 2- le-w! ( ) ;
