Author: wmb Date: 2010-01-29 08:03:08 +0100 (Fri, 29 Jan 2010) New Revision: 1720
Modified: ofw/fs/ext2fs/dir.fth ofw/fs/ext2fs/inode.fth ofw/fs/ext2fs/layout.fth ofw/fs/ext2fs/methods.fth ofw/fs/ext2fs/sb.fth Log: OLPC trac 9972 - support the ext2 LARGE_FILE extension and improve the error reporting in the presence of unsupported extensions.
Modified: ofw/fs/ext2fs/dir.fth =================================================================== --- ofw/fs/ext2fs/dir.fth 2010-01-29 05:13:22 UTC (rev 1719) +++ ofw/fs/ext2fs/dir.fth 2010-01-29 07:03:08 UTC (rev 1720) @@ -18,7 +18,7 @@ 0 instance value wf-type \ Type - 4 for directory, d# 10 for symlink, etc
: get-dirblk ( -- end? ) - lblk# bsize * file-size >= if true exit then + lblk# bsize um* dfile-size d< 0= if true exit then lblk# >pblk# to dir-block# false ; @@ -58,7 +58,7 @@ \ **** Select the next directory entry : next-dirent ( -- end? ) dirent-len@ dup diroff +! totoff +! - totoff @ file-size >= if true exit then + totoff @ u>d dfile-size d< 0= if true exit then diroff @ bsize = if lblk#++ get-dirblk if true exit then diroff off @@ -130,7 +130,7 @@ drop ( last ) ; : last-dirent ( -- free-bytes ) - file-size bsize /mod swap 0= if 1- then to lblk# ( ) + dfile-size bsize um/mod nip swap 0= if 1- then to lblk# ( ) lblk# >pblk# to dir-block# (last-dirent) drop dirent-len@ dirent-reclen - @@ -413,7 +413,7 @@
: file-info ( id -- false | id' s m h d m y len attributes name$ true ) inode# >r dirent-inode@ set-inode ( id ) - 1+ mtime unix-seconds> file-size file-attr file-name true + 1+ mtime unix-seconds> dfile-size drop file-attr file-name true r> set-inode ;
Modified: ofw/fs/ext2fs/inode.fth =================================================================== --- ofw/fs/ext2fs/inode.fth 2010-01-29 05:13:22 UTC (rev 1719) +++ ofw/fs/ext2fs/inode.fth 2010-01-29 07:03:08 UTC (rev 1720) @@ -23,8 +23,8 @@ : uid ( -- uid ) 2 +i short@ ; : uid! ( uid -- ) 2 +i short! update ; : filetype ( -- type ) file-attr h# f000 and ; -: file-size ( -- n ) 4 +i int@ ; -: file-size! ( n -- ) 4 +i int! update ; +: dfile-size ( -- d ) 4 +i int@ 108 +i int@ ; +: dfile-size! ( d -- ) 108 +i int! 4 +i int! update ; : atime ( -- seconds ) 8 +i int@ ; : atime! ( seconds -- ) 8 +i int! update ; : ctime ( -- seconds ) 12 +i int@ ; @@ -40,6 +40,7 @@ : #blks-held ( -- n ) 28 +i int@ ; : #blks-held! ( n -- ) 28 +i int! update ; : file-acl ( -- n ) 104 +i int@ ; +: dir-acl ( -- n ) 108 +i int@ ;
d# 12 constant #direct-blocks : direct0 ( -- adr ) 40 +i ;
Modified: ofw/fs/ext2fs/layout.fth =================================================================== --- ofw/fs/ext2fs/layout.fth 2010-01-29 05:13:22 UTC (rev 1719) +++ ofw/fs/ext2fs/layout.fth 2010-01-29 07:03:08 UTC (rev 1720) @@ -189,8 +189,8 @@ ;
: append-block ( -- ) - add-block ( block ) - file-size bsize / dup bsize * file-size! ( block #blocks ) + add-block ( block ) + dfile-size bsize um/mod nip dup bsize um* dfile-size! ( block #blocks ) 1+ >pblk int! update ;
Modified: ofw/fs/ext2fs/methods.fth =================================================================== --- ofw/fs/ext2fs/methods.fth 2010-01-29 05:13:22 UTC (rev 1719) +++ ofw/fs/ext2fs/methods.fth 2010-01-29 07:03:08 UTC (rev 1720) @@ -19,7 +19,7 @@ dirent-inode@ set-inode
add-block ( block# ) - file-size h# 400 + file-size! + dfile-size h# 400. d+ dfile-size! ( block# ) dup direct0 int! update ( block# ) block bsize erase update \ flush ( ) inode# first-dirent if true exit then ( ) @@ -136,7 +136,7 @@
\ EXT2FS file interface
-: ext2fsdflen ( 'fhandle -- d.size ) drop file-size 0 ; +: ext2fsdflen ( 'fhandle -- d.size ) drop dfile-size ;
: ext2fsdfalign ( d.byte# 'fh -- d.aligned ) drop swap bsize 1- invert and swap @@ -159,19 +159,24 @@ : ext2fsfread ( addr count 'fh -- #read ) drop dup bsize > abort" Bad size for ext2fsfread" - file-size lblk# bsize * - ( addr count rem ) + dfile-size lblk# bsize um* d- drop ( addr count rem ) umin swap ( actual addr ) lblk# read-file-block ( actual ) dup 0> if lblk#++ then ( actual ) ;
+: ext2fsnowrite ( addr count 'fh -- #written ) + ." Not writing to the ext2 filesystem because of unsupported extensions" cr + 2drop 0 +; : ext2fsfwrite ( addr count 'fh -- #written ) drop dup bsize > abort" Bad size for ext2fsfwrite" ( addr count ) - tuck lblk# bsize * + dup file-size u> if ( actual addr new ) - file-size! \ changing byte count, NOT #blks - else - drop + tuck 0 lblk# bsize um* d+ ( addr count d.new-size ) + dfile-size 2over d< if ( actual addr d.new ) + dfile-size! \ extending file ( actual addr ) + else ( actual addr d.new ) + 2drop \ not extending file ( actual addr ) then ( actual addr ) lblk# write-file-block ( actual )
@@ -191,7 +196,11 @@ >r bsize alloc-mem bsize initbuf dirent-inode@ r@ ['] ext2fsdflen ['] ext2fsdfalign ['] ext2fsfclose ['] ext2fsdfseek - r@ read = unknown-extensions? or if ['] nullwrite else ['] ext2fsfwrite then + r@ read = unknown-extensions? or if + ['] ext2fsnowrite + else + ['] ext2fsfwrite + then r> write = if ['] nullread else ['] ext2fsfread then true ; @@ -249,8 +258,8 @@ : seek ( offset.low offset.high -- error? ) ext2fs-fd ['] dfseek catch if 2drop true else false then ; -: size ( -- d ) file-size 0 ; -: load ( adr -- size ) file-size read ; +: size ( -- d ) dfile-size ; +: load ( adr -- size ) dfile-size drop read ; \ : files ( -- ) begin file-name type cr next-dirent until ;
\ LICENSE_BEGIN
Modified: ofw/fs/ext2fs/sb.fth =================================================================== --- ofw/fs/ext2fs/sb.fth 2010-01-29 05:13:22 UTC (rev 1719) +++ ofw/fs/ext2fs/sb.fth 2010-01-29 07:03:08 UTC (rev 1720) @@ -54,7 +54,7 @@
23 +sbl h# ffffffff invert and \ Accept all compat extensions 24 +sbl h# 00000002 invert and or \ Incompatible - accept FILETYPE - 25 +sbl h# 00000001 invert and or \ RO - accept SPARSE_SUPER + 25 +sbl h# 00000003 invert and or \ RO - accept SPARSE_SUPER and LARGE_FILE ;
: do-alloc ( adr len -- ) " dma-alloc" $call-parent ;
