Author: wmb Date: Wed Aug 4 06:44:34 2010 New Revision: 1907 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/1907
Log: SD driver - added "show-cid" command.
Modified: dev/mmc/sdhci/sdhci.fth dev/mmc/sdhci/sdmmc.fth
Modified: dev/mmc/sdhci/sdhci.fth ============================================================================== --- dev/mmc/sdhci/sdhci.fth Tue Aug 3 21:52:21 2010 (r1906) +++ dev/mmc/sdhci/sdhci.fth Wed Aug 4 06:44:34 2010 (r1907) @@ -408,7 +408,7 @@
\ Get Card-specific data : get-csd ( -- ) rca h# 0909 0 cmd csd get-response136 ; \ CMD9 R2 -: get-cid ( -- ) rca h# 0a09 0 cmd cid get-response136 ; \ CMD10 R2 UNTESTED +: get-cid ( -- ) rca h# 0a09 0 cmd cid get-response136 ; \ CMD10 R2
: stop-transmission ( -- ) rca h# 0c1b 0 cmd ; \ CMD12 R1b UNTESTED
@@ -824,6 +824,7 @@ card-clock-25
get-csd \ Cmd 9 - Get card-specific data + get-cid \ Cmd 10 - Get card ID
select-card \ Cmd 7 - Select
@@ -962,6 +963,21 @@ unmap-regs ;
+: cid@ ( offset -- byte ) cid + c@ ; +: .nospace <# u#s u#> type ; +: show-cid ( -- ) + base @ >r hex + ." Mfg ID: " d# 14 cid@ ." 0x" .nospace + ." OEM ID: " d# 13 cid@ emit d# 12 cid@ emit + ." Name: " 7 d# 11 do i cid@ emit -1 +loop + ." Rev: " 6 cid@ dup 4 rshift .nospace ." ." h# f and .nospace + decimal + ." Date: " 0 cid@ 1 cid@ bwjoin dup 4 rshift d# 2000 + .nospace ." -" h# f and .nospace + hex + ." SN: " 2 cid@ 3 cid@ 4 cid@ 5 cid@ bljoin ." 0x" .nospace + r> base ! +; + \ The bit numbering follows the table on page 78 of the \ SD Physical Layer Simplified Specification Version 2.00.
Modified: dev/mmc/sdhci/sdmmc.fth ============================================================================== --- dev/mmc/sdhci/sdmmc.fth Tue Aug 3 21:52:21 2010 (r1906) +++ dev/mmc/sdhci/sdmmc.fth Wed Aug 4 06:44:34 2010 (r1907) @@ -105,6 +105,8 @@ : load ( addr -- size ) " load" label-package $call-method ;
: size ( -- d.size ) " size" label-package $call-method ; + +: show-cid ( -- ) " show-cid" $call-parent ; headers
\ LICENSE_BEGIN
