Author: wmb Date: 2009-08-04 03:32:33 +0200 (Tue, 04 Aug 2009) New Revision: 1271
Modified: cpu/x86/iirfilter.fth Log: Commented IIR upsampling filter code.
Modified: cpu/x86/iirfilter.fth =================================================================== --- cpu/x86/iirfilter.fth 2009-08-04 00:46:03 UTC (rev 1270) +++ cpu/x86/iirfilter.fth 2009-08-04 01:32:33 UTC (rev 1271) @@ -1,12 +1,22 @@ -purpose: IIR digital filter support +purpose: IIR digital upsampling filter
-\ iir-cascade implements the "Folded Cascade First Order Filters" -\ structure as shown on page 274 of _Multirate Signal Processing -\ for Communications Systems_ by fredric j harris, Prentice Hall 2004 -\ ISBN 0-13-146511-2 +\ This file implements x2 and x3 upsampling filters using techniques +\ described in chapter 10 of _Multirate Signal Processing for Communications +\ Systems_ by fredric j harris, Prentice Hall 2004, ISBN 0-13-146511-2 +\ The filters may be cascaded for x6 upsampling (e.g. for 8kHz -> 48kHz)
-d# 14 constant mulscale +d# 15 constant mulscale \ Bits for fractional multipliers
+0 [if] + +\ iir-cascade-z2 implements a folded cascade of multiple sections +\ of a second-order IIR filter block in a polynomial in Z^2. +\ This is the basic building block for half-band all-pass +\ recursive filters, as described in section 10.2 of the book +\ cited above. +\ This code is commented out because we don't use it directly, +\ instead using the -z1 variant below in a polyphase structure. + code iir-cascade-z2 ( sample weights z #sections -- out ) cx pop \ CX: Number of sections
@@ -28,20 +38,29 @@
0 [bp] dx mov dx 4 [bp] mov - bx 0 [bp] mov \ Update M[i] + bx 0 [bp] mov \ Update Z[i]
- 8 [bp] bp lea \ Point to next M[i] + 8 [bp] bp lea \ Point to next Z[i] loopa
0 [bp] dx mov dx 4 [bp] mov - ax 0 [bp] mov \ Update M[i] + ax 0 [bp] mov \ Update Z[i]
bp pop \ Restore BP si pop \ Restore SI ax push \ Return value c;
+\ iir-cascade-z1 is the same basic structure as iir-cascade-z2, +\ but the Z^-2 delays have been replaced by Z^-1. It is used +\ in the polyphase upsampler "up2". When the rate is doubled, +\ a zero sample is inserted between each pair of input samples, +\ causing every other computation of the Z^-2 polynomial to be +\ unnecessary. The basic block can thus be restructured to have +\ a single delay element, and the block only has to run at half +\ the rate. See section 10.6 (figure 10.48) of the book. + code iir-cascade-z1 ( sample weights z #sections -- out ) cx pop \ CX: Number of sections
@@ -54,25 +73,32 @@ bx push \ Saved BP on stack begin ax bx mov \ Save last value - d# 4 [bp] ax sub \ last - M[i+1] + d# 4 [bp] ax sub \ last - Z[i+1]
- 0 [si] imul \ alpha[i] * (last - M[i+1]) (kills DX) + 0 [si] imul \ alpha[i] * (last - Z[i+1]) (kills DX) 4 [si] si lea \ Increment alpha pointer mulscale # dx ax shrd \ Scale down by multiplier scale factor
- d# 0 [bp] ax add \ M[i] + alpha[i] * (last - M[i+1]) + d# 0 [bp] ax add \ Z[i] + alpha[i] * (last - Z[i+1])
- 4 [bp] bp lea \ Point to next M[i] + 4 [bp] bp lea \ Point to next Z[i] loopa - ax 0 [bp] mov \ Update M[i] + ax 0 [bp] mov \ Update Z[i]
+\ iir-cascade-z2g implements the generalized second-order +\ low pass filter cascade as shown in section 10.5.1 (figure 10.35) +\ of the book. The generalized form allows arbitrary bandwidths +\ as opposed to the half-band restriction of the simplifed form. +\ We use this form for 3x upsampling so we can set the lowpass +\ frequency to Fnyquist/3. + code iir-cascade-z2g ( sample weights z #sections -- out ) cx pop \ CX: Number of sections
@@ -121,12 +147,14 @@ c;
+\ Convert a decimal fraction to a scaled integer multiplier : mul: ( "coef" -- ) safe-parse-word push-decimal $number drop pop-base ( n ) 1 mulscale lshift d# 1,000,000,000 */ ( n' ) , ;
+\ Clip too-large sample values to +- 15 bits code saturate ( s -- s' ) ax pop d# 32767 # ax cmp > if @@ -146,44 +174,56 @@ ; [then]
-\ upsample by 4 - 2 constant #coefs
\ This is for a 9-pole, 9-zero 2-path all-pass halfband IIR filter +\ From page 278 of the book create weights0 mul: .101467517 mul: .612422841 \ Even path create weights1 mul: .342095596 mul: .867647439 \ Odd path
0 [if] \ This is for a 5-pole, 5-zero 2-path all-pass halfband IIR filter +\ From page 276 of the book create weights2 mul: .141348600 \ Even path create weights3 mul: .589994800 \ Odd path [then]
\ This is for a 5-pole, 5-zero 2-path all-pass third-band IIR filter \ G0 and G1 use iir-cascade-z2g, H1 uses iir-cascade-z1 +\ This is derived from the 5-pole halfband coefficients according +\ to the formulas on page 291, with fb/fs = 1/6 (fb/fnyquist = 1/3). +\ The book has a missing sign somewhere, because without the minus +\ signs on c1 and b, you end up with the corner frequency at 2/6 +\ instead of 1/6. I had to figure that out the hard way, by trial +\ and error (looking at spectra of impulse responses). If you +\ replace b with -b in equation 10.25, the c1's work out automatically. + +\ c1 c2 create coefg0 mul: -.605502011 mul: .211004022 \ Even path G0 create coefg1 mul: -.817448745 mul: .634897489 \ Odd path G1 +\ b create coefh1 mul: -.267949192
-#coefs 1+ 2* /n* constant buflen -buflen buffer: z0 \ First upsampler even path delay buffer -buflen buffer: z1 \ First upsampler odd path delay buffer -buflen buffer: z2 \ 3x upsampler even path G0 delay buffer -buflen buffer: z3 \ 3x upsampler odd path G1 delay buffer -buflen buffer: z4 \ 3x upsampler odd path H1 delay buffer +2 1+ /n* constant buflen0 \ 2 stages of Z^-1 plus final feedback
-: init-upsample - z0 buflen erase - z1 buflen erase - z2 buflen erase - z3 buflen erase - z4 buflen erase +buflen0 buffer: z0 \ First upsampler even path delay buffer +buflen0 buffer: z1 \ First upsampler odd path delay buffer + +1 1+ 2* /n* constant buflen0 \ 1 stage of Z^-2 plus final feedback + +buflen1 buffer: z2 \ 3x upsampler even path G0 delay buffer +buflen1 buffer: z3 \ 3x upsampler odd path G1 delay buffer +buflen1 buffer: z4 \ 3x upsampler odd path H1 delay buffer + +: init-upsample ( -- ) + z0 buflen0 erase + z1 buflen0 erase + z2 buflen1 erase + z3 buflen1 erase + z4 buflen1 erase ;
-0 value lastsample - \ This is a polyphase decomposition of upsampling by 2 \ The filter prototype for each path is a polynomial in Z^2, \ but when you apply the polyphase transform with Nobel's identity, @@ -194,6 +234,8 @@ ;
0 [if] +0 value lastsample + \ This is the base rate (non-polyphase) version of up2 \ Both paths run for each sample, with Z^-1 between the \ paths, summing the paths to get a lowpass output. @@ -234,6 +276,7 @@ : 8khz>48khz ( inbuf #samples stride outbuf -- ) to sample-stride ( inbuf #samples outbuf ) sample-outp ! ( inbuf #samples ) + init-upsample ( inbuf #samples ) 0 ?do ( inbuf ) dup sample-stride + ( inbuf inbuf' ) swap <w@ ( inbuf' sample ) @@ -247,6 +290,7 @@ : 16khz>48khz ( inbuf #samples stride outbuf -- ) to sample-stride ( inbuf #samples outbuf ) sample-outp ! ( inbuf #samples ) + init-upsample ( inbuf #samples ) 0 ?do ( inbuf ) dup sample-stride + ( inbuf inbuf' ) swap <w@ ( inbuf' sample ) @@ -254,3 +298,28 @@ loop ( inbuf ) drop ; + +0 [if] +\ Here is some Matlab/Octave code to do the "coefg.." coefficient +\ transformations +function retval = c1(a, b) + retval = 2 * b * (1 + a) / (1 + a * b * b); +end +function retval = c2(a, b) + retval = ((b * b) + a) / (1 + a * b * b); +end +function retval = cvtb(frac) + retval = (1 - tan(pi * frac)) / (1 + tan(pi * frac)); +end +function cvtfilt (bw) % bw is fb/fs + a0 = .141348600 + a1 = .589994800 + + b = cvtb(bw) + c10 = c1(a0, b) + c20 = c2(a0, b) + c11 = c1(a1, b) + c21 = c2(a1, b) +end +cvtfilt(1/6); +[then]
