Author: wmb Date: Thu Jan 27 02:16:42 2011 New Revision: 2155 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2155
Log: USB - handle overcurrent conditions more gracefully.
Modified: dev/usb2/hcd/probehub.fth
Modified: dev/usb2/hcd/probehub.fth ============================================================================== --- dev/usb2/hcd/probehub.fth Thu Jan 27 02:15:15 2011 (r2154) +++ dev/usb2/hcd/probehub.fth Thu Jan 27 02:16:42 2011 (r2155) @@ -13,6 +13,21 @@ : reset-hub-port ( port -- ) PORT_RESET DR_PORT " set-feature" $call-parent drop d# 20 ms ; : clear-status-change ( port -- ) C_PORT_CONNECTION DR_PORT " clear-feature" $call-parent drop ; : parent-set-target ( dev -- ) " set-target" $call-parent ; +: hub-error? ( -- error? ) + hub-buf 4 0 DR_HUB " get-status" $call-parent ( actual usberror ) + nip if ( ) + ." Failed to get hub status" cr + true ( true ) + else ( ) + hub-buf 2+ c@ 2 and if ( ) + ." USB Hub shut down due to over-current" cr ( ) + true ( true ) + else ( ) + false ( false ) + then ( error? ) + then ( error? ) +; + : get-port-status ( port -- error? ) hub-buf 4 2 pick DR_PORT " get-status" $call-parent ( port actual usberror ) nip if ( port ) @@ -28,6 +43,11 @@ drop false exit ( -- false ) then ( port )
+ hub-buf c@ 8 and if ( port ) + ." Hub port " . ." is over current" cr + false exit ( -- false ) + then + hub-buf 2+ c@ 1 and if ( port ) \ Status changed clear-status-change ( ) @@ -58,17 +78,17 @@ " setup-new-node" $call-parent if execute then ( ) ;
-: hub-#ports ( -- n ) +: hub-#ports ( -- #ports ) hub-buf 8 0 0 HUB DR_HUB " get-desc" $call-parent nip if ." Failed to get hub descriptor" cr 0 exit then - hub-buf 2 + c@ 1+ ( #ports ) + hub-buf 2 + c@ ( #ports ) ; : hub-delay ( -- #2ms ) hub-buf 5 + c@ ;
: power-hub-ports ( #ports -- ) - 1 ?do i power-hub-port loop ( ) + 1+ 1 ?do i power-hub-port loop ( )
hub-delay 2* ms ( )
@@ -88,25 +108,36 @@ external : probe-hub ( dev -- ) dup parent-set-target ( hub-dev ) - hub-#ports ( hub-dev #ports ) + hub-#ports dup 0= if ( hub-dev #ports ) + 2drop exit ( -- ) + then ( hub-dev #ports )
- " configuration#" get-int-property + " configuration#" get-int-property ( hub-dev #ports config# ) " set-config" $call-parent ( hub-dev #ports usberr ) if drop ." Failed to set config for hub at " u. cr exit then ( hub-dev #ports )
- dup power-hub-ports ( hub-dev #ports ) + dup power-hub-ports ( hub-dev #ports )
- 1 ?do ( hub-dev ) - dup i safe-probe-hub-port ( hub-dev ) - loop ( hub-dev ) - drop ( ) + hub-error? if 2drop exit then ( hub-dev #ports ) + + 1+ 1 ?do ( hub-dev ) + dup i safe-probe-hub-port ( hub-dev ) + loop ( hub-dev ) + drop ( ) ;
: probe-hub-xt ( -- adr ) ['] probe-hub ;
: do-reprobe-hub ( dev -- ) dup parent-set-target ( hub-dev ) - hub-#ports 1 ?do ( hub-dev ) + + hub-#ports dup 0= if ( hub-dev #ports ) + 2drop exit ( -- ) + then ( hub-dev #ports ) + + hub-error? if 2drop exit then ( hub-dev #ports ) + + 1+ 1 ?do ( hub-dev ) dup i port-status-changed? if ( hub-dev connected? ) if ( hub-dev ) dup i safe-probe-hub-port ( hub-dev )
