Author: wmb Date: Thu Nov 15 21:21:52 2012 New Revision: 3431 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3431
Log: OLPC ARM - Added device node for Video SRAM (/vsram) and some DCON panel description properties, per jnettlet.
Modified: cpu/arm/olpc/1.75/lcdcfg.fth
Modified: cpu/arm/olpc/1.75/lcdcfg.fth ============================================================================== --- cpu/arm/olpc/1.75/lcdcfg.fth Thu Nov 15 21:02:44 2012 (r3430) +++ cpu/arm/olpc/1.75/lcdcfg.fth Thu Nov 15 21:21:52 2012 (r3431) @@ -1,3 +1,16 @@ +h# d102.0000 constant video-sram-pa \ Base of Video SRAM +h# 1.0000 constant /video-sram + +dev / +new-device + " vsram" device-name + video-sram-pa /video-sram reg + + " marvell,mmp-vsram" +compatible + d# 64 " granularity" integer-property +finish-device +device-end + dev /display new-device " panel" device-name @@ -6,6 +19,9 @@ " OLPC DCON panel" model : +i encode-int encode+ ;
+ h# 20001102 " set-clock-divider-regval" integer-property + d# 4324096 " max-fb-size" integer-property + decimal 0 0 encode-bytes \ xres, yres, refresh, clockhz, left, right, top, bottom, hsync, vsync, flags, widthmm, heightmm
