Author: wmb Date: Sat Dec 31 21:53:40 2011 New Revision: 2793 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2793
Log: OLPC trac 11562 - security - RTC anti-rollback - Fixed stack bug that caused boot failures in the face of an invalid rtcreset.sig file.
Modified: cpu/x86/pc/olpc/security.fth
Modified: cpu/x86/pc/olpc/security.fth ============================================================================== --- cpu/x86/pc/olpc/security.fth Sat Dec 31 21:01:59 2011 (r2792) +++ cpu/x86/pc/olpc/security.fth Sat Dec 31 21:53:40 2011 (r2793) @@ -1075,20 +1075,20 @@ 0 0 2value nonce$ 0 0 2value rtcsig$ : rtc-format-error ( -- done? ) - ." RTC Reset format error" ?lease-error-cr true + " RTC Reset format error" ?lease-error-cr true ; : check-rtc-key ( data$ -- done? ) \ rtc01: SN currentrtc nonce newrtc sig0N: ... \ Isolate data from line newline left-parse-string 2nip ( rem$ )
bl left-parse-string " rtc01:" $= 0= if ( rem$ ) - ." Unknown format" ?lease-error-cr ( rem$ ) + " Unknown format" ?lease-error-cr ( rem$ ) 2drop true exit ( -- true ) then ( rem$ )
bl left-parse-string ( rem$ serial$ ) my-sn$ $= 0= if ( rem$ ) -\ ." Wrong serial number" ?lease-error-cr ( rem$ ) +\ " Wrong serial number" ?lease-error-cr ( rem$ ) 2drop false exit ( -- false ) then ( rem$ )
@@ -1106,7 +1106,7 @@ rtcsig$ " sha256" signature-good? if ( ) newrtc$ nonce$ currentrtc$ fix-rtc-timestamps ( ) else - ." Bad signature " ?lease-error-cr ( ) + " Bad signature " ?lease-error-cr ( ) then ( ) true ( done? ) ; @@ -1116,9 +1116,9 @@ show-dot null$ cn-buf place " rtcreset.sig" open-security? if exit then >r ( r: ih ) - " RTCRESET found - " ?lease-debug - load-started - leasekey$ to pubkey$ + " RTCRESET found - " ?lease-debug + load-started + leasekey$ to pubkey$ begin sec-line-buf /sec-line-max r@ read-line if ( actual -eof? ) 2drop r> close-file drop exit @@ -1130,7 +1130,7 @@ repeat ( actual ) drop ( ) " No matching records" ?lease-error-cr ( ) - r> close-file drop false ( false ) + r> close-file drop ( ) ;
[ifdef] reflash-ec
