Author: wmb Date: 2009-09-03 07:16:25 +0200 (Thu, 03 Sep 2009) New Revision: 1345
Modified: cpu/x86/pc/olpc/via/ioinit.fth cpu/x86/pc/olpc/via/startcominit.fth Log: Via - yet another early startup change to handle A-test vs B-test differences, this time having to do with the SDIO power switch for SDIO slot 2.
Modified: cpu/x86/pc/olpc/via/ioinit.fth =================================================================== --- cpu/x86/pc/olpc/via/ioinit.fth 2009-09-03 05:14:31 UTC (rev 1344) +++ cpu/x86/pc/olpc/via/ioinit.fth 2009-09-03 05:16:25 UTC (rev 1345) @@ -222,7 +222,7 @@ [then]
[ifdef] xo-board - 9b ff 89 mreg \ 80 undoc but is LVDS power. 00 forces LVDS power off, 80 lets 3d5.D2[7,6,3] control it; 1 selects GPO11/12 instead of CR_PWSEL/CR_PWOFF (DCONLOAD) + 9b ff 88 mreg \ 80 undoc but is LVDS power. 00 forces LVDS power off, 80 lets 3d5.D2[7,6,3] control it; 1 selects GPO11/12 instead of CR_PWSEL/CR_PWOFF (DCONLOAD) 9f ff 08 mreg \ Slot 3 is SDIO, no pullup on KB/MS, fastest SD [then] [ifdef] demo-board
Modified: cpu/x86/pc/olpc/via/startcominit.fth =================================================================== --- cpu/x86/pc/olpc/via/startcominit.fth 2009-09-03 05:14:31 UTC (rev 1344) +++ cpu/x86/pc/olpc/via/startcominit.fth 2009-09-03 05:16:25 UTC (rev 1345) @@ -24,64 +24,64 @@ \ If the SERIAL_EN jumper is installed, or if the machine is an A-test, \ route the external pin to the UART; otherwise leave it connected to the VCP port.
- acpi-io-base 48 + port-rb h# 10 # al test 0= if - \ SERIAL_EN is installed, so put the A-test ID in AL so we can check - \ a single condition at the end of the logic. - h# d0 # al mov - else - \ SERIAL_EN is not installed. Determine the board ID. + \ SERIAL_EN is not installed. Determine the board ID.
- \ First we check for a cached board ID in CMOS RAM, to avoid the - \ possibly time-consuming operation of asking the EC. + \ First we check for a cached board ID in CMOS RAM, to avoid the + \ possibly time-consuming operation of asking the EC.
- \ To read the high half of CMOS RAM we must enable it - d# 17 0 devfunc - 4e 18 18 mreg \ Enable ports 74/75 for CMOS RAM access - 10 res be like Phx - end-table + \ To read the high half of CMOS RAM we must enable it + d# 17 0 devfunc + 4e 18 18 mreg \ Enable ports 74/75 for CMOS RAM access - 10 res be like Phx + end-table
- h# 83 # al mov al h# 74 # out h# 75 # al in \ check byte - should be ~board-id - al ah mov ah not \ ~check byte in AH - h# 82 # al mov al h# 74 # out h# 75 # al in \ board-id in AL + h# 83 # al mov al h# 74 # out h# 75 # al in \ check byte - should be ~board-id + al ah mov ah not \ ~check byte in AH + h# 82 # al mov al h# 74 # out h# 75 # al in \ board-id in AL
- al ah cmp 0<> if \ If the check byte matches, fall through with the ID in AL + al ah cmp 0<> if \ If the check byte matches, fall through with the ID in AL
- \ If check byte is wrong, we have to ask the EC + \ If check byte is wrong, we have to ask the EC
- h# 6c # al in \ EC status register - 2 # al and \ input buffer full bit - 0<> if \ If the bit is nonzero, we can't send a command yet - \ We don't wait for the EC; if it is busy we assume B-test - \ It shouldn't be busy at this point because we haven't tried to talk to it yet - h# d1 # al mov \ EC busy - report B-test + h# 6c # al in \ EC status register + 2 # al and \ input buffer full bit + 0<> if \ If the bit is nonzero, we can't send a command yet + \ We don't wait for the EC; if it is busy we assume B-test + \ It shouldn't be busy at this point because we haven't tried to talk to it yet + h# d1 # al mov \ EC busy - report B-test + else + h# 19 # al mov al h# 6c # out \ Send board ID command to EC + d# 200 # cx mov \ Wait up to 200 mS for the EC to respond + begin + d# 1000 wait-us \ 1 mS delay so we don't pound on the EC + h# 6c # al in \ Get status register + 3 # al and \ Check for output buffer full + 1 # al cmp + loopne + <> if \ Not equal means timeout + h# d1 # al mov \ EC timeout - report B-test else - h# 19 # al mov al h# 6c # out \ Send board ID command to EC - d# 200 # cx mov \ Wait up to 200 mS for the EC to respond - begin - d# 1000 wait-us \ 1 mS delay so we don't pound on the EC - h# 6c # al in \ Get status register - 3 # al and \ Check for output buffer full - 1 # al cmp - loopne - <> if \ Not equal means timeout - h# d1 # al mov \ EC timeout - report B-test - else - h# 68 # al in \ Get board ID byte from EC - then + h# 68 # al in \ Get board ID byte from EC then then then
- \ Now AL contains the board ID or a surrogate that will cause the - \ desired result for the test below. + \ Now AL contains the board ID h# d1 # al cmp u< if + \ A-test d# 17 0 devfunc - \ The following is for UART on VCP port - 46 c0 40 mreg - \ The following is for UART on DVP port - \ 46 c0 c0 mreg + 9b 01 01 mreg \ 1 selects GPO11/12 instead of CR_PWSEL/CR_PWOFF (DCONLOAD) + 46 c0 40 mreg \ Enable UART on VCP port end-table + else + \ B-test or later + \ For B-test and later, we only enable serial if the jumper is present + acpi-io-base 48 + port-rb h# 10 # al test 0= if + d# 17 0 devfunc + 46 c0 40 mreg \ Enable UART on VCP port + end-table + then then - + d# 17 0 devfunc \ Standard COM2 and COM1 IRQ routing b2 ff 34 mreg
