Author: wmb Date: Thu Jan 20 02:14:05 2011 New Revision: 2133 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2133
Log: Eliminate the use of the "md5sum" command in the builder scripts for XO-1.75, because OS-X doesn't have that command.
Added: forth/lib/md5file.fth Modified: cpu/arm/olpc/1.75/sd8686.bth cpu/arm/olpc/1.75/verify.bth
Modified: cpu/arm/olpc/1.75/sd8686.bth ============================================================================== --- cpu/arm/olpc/1.75/sd8686.bth Thu Jan 20 02:12:45 2011 (r2132) +++ cpu/arm/olpc/1.75/sd8686.bth Thu Jan 20 02:14:05 2011 (r2133) @@ -3,23 +3,8 @@ command: &builder &this build-now
-char * value prefix -\needs $md5digest1 fload ${BP}/ofw/ppp/md5.fth -: $md5sum-file ( filename$ -- ) - 2dup $read-file ( filename$ adr len ) - 2dup $md5digest1 ( filename$ adr len md5$ ) - 2swap free-mem ( filename$ md5$ ) - " md5string" $new-file ( filename$ md5$ ) - bounds ?do ( filename$ ) - i c@ push-hex <# u# u# u#> ofd @ fputs pop-base - loop ( filename$ ) - " " ofd @ fputs ( filename$ ) - prefix ofd @ fputc ( filename$ ) - ofd @ fputs ( ) - fcr - ofd @ fclose -; - +\needs to-file fload ${BP}/forth/lib/tofile.fth +\needs $md5sum-file fload ${BP}/forth/lib/md5file.fth
fload ${BP}/cpu/arm/olpc/1.75/wlan-version.fth
@@ -33,14 +18,14 @@ " wget -q http://dev.laptop.org/pub/firmware/libertas/thinfirm/$%7BWLAN_FILE%7D.bin" expand$ $sh " wget -q http://dev.laptop.org/pub/firmware/libertas/thinfirm/$%7BWLAN_FILE%7D.bin.md..." expand$ $sh
-bl to prefix " ${WLAN_FILE}.bin" expand$ $md5sum-file +to-file md5string " " " ${WLAN_FILE}.bin" expand$ $md5sum-file " cmp md5string ${WLAN_FILE}.bin.md5" expand$ $sh
" mv ${WLAN_FILE}.bin sd8686.bin" expand$ $sh
" wget -q http://dev.laptop.org/pub/firmware/libertas/sd8686_helper.bin" expand$ $sh " wget -q http://dev.laptop.org/pub/firmware/libertas/sd8686_helper.bin.md5" expand$ $sh -char * to prefix " sd8686_helper.bin" $md5sum-file +to-file md5string " *" " sd8686_helper.bin" $md5sum-file " cmp md5string sd8686_helper.bin.md5" expand$ $sh
" rm ${WLAN_FILE}.bin.md5 sd8686_helper.bin.md5 md5string" expand$ $sh
Modified: cpu/arm/olpc/1.75/verify.bth ============================================================================== --- cpu/arm/olpc/1.75/verify.bth Thu Jan 20 02:12:45 2011 (r2132) +++ cpu/arm/olpc/1.75/verify.bth Thu Jan 20 02:14:05 2011 (r2133) @@ -3,6 +3,9 @@ command: &builder &this build-now
+\needs to-file fload ${BP}/forth/lib/tofile.fth +\needs $md5sum-file fload ${BP}/forth/lib/md5file.fth + fload ${BP}/cpu/arm/olpc/1.75/crypto-version.fth
" wget -q http://dev.laptop.org/pub/firmware/crypto/$%7BKEYS%7D/os.public -O os.public" expand$ $sh @@ -13,10 +16,11 @@ " wget -q http://dev.laptop.org/pub/firmware/crypto/bios_verify-$%7BCRYPTO_VERSION%7D...." expand$ $sh " wget -q http://dev.laptop.org/pub/firmware/crypto/bios_verify-$%7BCRYPTO_VERSION%7D...." expand$ $sh
-" md5sum -b bios_verify-${CRYPTO_VERSION}.img | cmp - bios_verify-${CRYPTO_VERSION}.img.md5" expand$ $sh +to-file md5string " *" " bios_verify-${CRYPTO_VERSION}.img" expand$ $md5sum-file +" cmp md5string bios_verify-${CRYPTO_VERSION}.img.md5" expand$ $sh
" mv bios_verify-${CRYPTO_VERSION}.img verify.img" expand$ $sh -" rm bios_verify-${CRYPTO_VERSION}.img.md5" expand$ $sh +" rm bios_verify-${CRYPTO_VERSION}.img.md5 md5string" expand$ $sh
\ This forces the creation of an verify.log file, so we don't re-fetch writing verify.version
Added: forth/lib/md5file.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ forth/lib/md5file.fth Thu Jan 20 02:14:05 2011 (r2133) @@ -0,0 +1,28 @@ +purpose: Emulate the Linux md5sum command + +\needs $md5digest1 fload ${BP}/ofw/ppp/md5.fth + +: $md5sum-file ( prefix$ filename$ -- ) + \ Read file into memory and compute its MD5 hash + 2dup $read-file ( prefix$ filename$ adr len ) + 2dup $md5digest1 ( prefix$ filename$ adr len md5$ ) + 2swap free-mem ( prefix$ filename$ md5$ ) + + \ Write the hash and the filename in the same format as + \ the output of the Linux "md5sum" command. prefix$ should + \ be " *" to match the output of "md5sum -b" and " " + \ to match the output of "md5sum" without -b. + + \ Output MD5 in lower case ASCII hex + push-hex ( prefix$ filename$ md5$ ) + bounds ?do ( prefix$ filename$ ) + i c@ <# u# u# u#> type + loop ( prefix$ filename$ ) + pop-base ( prefix$ filename$ ) + + \ ... followed by " filename" or " *filename" + ." " ( prefix$ filename$ ) + 2swap type ( filename$ ) + type ( ) + cr +;
