Author: wmb Date: 2008-11-11 23:53:41 +0100 (Tue, 11 Nov 2008) New Revision: 1002
Added: cpu/x86/pc/neptune/mfgdata.fth Modified: cpu/x86/pc/neptune/addrs.fth cpu/x86/pc/neptune/devices.fth cpu/x86/pc/neptune/fw.bth Log: Neptune - added a manufacturing data area to FLASH.
Modified: cpu/x86/pc/neptune/addrs.fth =================================================================== --- cpu/x86/pc/neptune/addrs.fth 2008-11-11 20:40:53 UTC (rev 1001) +++ cpu/x86/pc/neptune/addrs.fth 2008-11-11 22:53:41 UTC (rev 1002) @@ -5,6 +5,7 @@ h# 10.0000 constant /rom \ Size of boot ROM
h# 0.0000 constant config-vars-offset +h# 0.1000 constant mfg-data-offset h# 8.0000 constant dropin-offset rom-pa dropin-offset + constant dropin-base h# 8.0000 constant dropin-size
Modified: cpu/x86/pc/neptune/devices.fth =================================================================== --- cpu/x86/pc/neptune/devices.fth 2008-11-11 20:40:53 UTC (rev 1001) +++ cpu/x86/pc/neptune/devices.fth 2008-11-11 22:53:41 UTC (rev 1002) @@ -238,6 +238,8 @@ ; [then]
+fload ${BP}/cpu/x86/pc/neptune/mfgdata.fth + \ Create the alias unless it already exists : $?devalias ( alias$ value$ -- ) 2over not-alias? if $devalias exit then ( alias$ value$ alias$ )
Modified: cpu/x86/pc/neptune/fw.bth =================================================================== --- cpu/x86/pc/neptune/fw.bth 2008-11-11 20:40:53 UTC (rev 1001) +++ cpu/x86/pc/neptune/fw.bth 2008-11-11 22:53:41 UTC (rev 1002) @@ -239,29 +239,6 @@
devalias net /ethernet
-8 buffer: mac-address-buf -: random-mac-address ( -- adr len ) - mac-address-buf @ 0= if - \ Get a pseudo-random number - - \ Seed it with the real time clock and the timestamp counter - time&date xor xor xor xor xor ( seed ) - tsc@ xor xor ( seed' ) - - \ Scramble it a bit with a linear congruence - d# 1103515245 * d# 12345 + h# 7FFFFFFF and ( rn1 ) - dup mac-address-buf ! ( rn1 ) - d# 1103515245 * d# 12345 + h# 7FFFFFFF and ( rn2 ) - mac-address-buf 3 + ! ( ) - - \ Turn off the multicast bit and turn on the locally-assigned bit - mac-address-buf c@ h# fe and 2 or mac-address-buf c! - then - - mac-address-buf 6 -; -' random-mac-address to system-mac-address - \ false to stand-init-debug? true to stand-init-debug?
Added: cpu/x86/pc/neptune/mfgdata.fth =================================================================== --- cpu/x86/pc/neptune/mfgdata.fth (rev 0) +++ cpu/x86/pc/neptune/mfgdata.fth 2008-11-11 22:53:41 UTC (rev 1002) @@ -0,0 +1,153 @@ +purpose: Save manufacturing data in a separate FLASH sector +\ See license at end of file + +\ Create a node below the top-level FLASH node to access the portion +\ containing the manufacturing data. +0 0 mfg-data-offset <# u#s u#> " flash" begin-package + " mfgdata" device-name + + h# 1000 constant /device \ 4K - SST49LF080A sector size + fload ${BP}/dev/subrange.fth +end-package + +false value using-mfg-data? + +0 value saved-nvram-node +0 value saved-config-mem +0 value saved-config-size + +0 value mfg-config-mem +0 value mfg-config-size +0 value mfg-data-node + +: unselect-mfg-data ( -- ) + using-mfg-data? if + saved-nvram-node to nvram-node 0 to saved-nvram-node + saved-config-mem to config-mem 0 to saved-config-mem + saved-config-size to config-size 0 to saved-config-size + false to using-mfg-data? + then +; +: dangerous-select-mfg-data ( -- ) + using-mfg-data? if exit then + + mfg-data-node 0= if + " /mfgdata" open-dev to mfg-data-node + mfg-data-node 0= abort" Can't open /mfgdata" + " size" mfg-data-node $call-method d>s to mfg-config-size + mfg-config-size alloc-mem to mfg-config-mem + then + + nvram-node to saved-nvram-node + config-mem to saved-config-mem + config-size to saved-config-size + + mfg-data-node to nvram-node + mfg-config-mem to config-mem + mfg-config-size to config-size + + true to using-mfg-data? +; + +stand-init: Manufacturing data + dangerous-select-mfg-data + read-nvram \ Read the manufacturing data into memory + read-ge-area \ Incorporate it into the config variables + unselect-mfg-data +; + +: 2u#: u# u# [char] : hold drop ; +: encode-enaddr ( adr len -- adr' len' ) \ binary to ASCII + 6 <> if " " exit then + 6 bounds do i c@ loop ( b0 b1 b2 b3 b4 b5 b6 ) + push-hex + <# 2u#: 2u#: 2u#: 2u#: 2u#: u# u# u#> + pop-base +; + +: decode-ether-byte ( $ dst-adr -- $' dst-adr' ) + >r ( $ r: dst-adr ) + [char] : left-parse-string ( $' head$ r: dst-adr ) + $number if 0 then ( $ n r: dst-adr ) + 0 max h# ff min ( $ n' r: dst-adr ) + r@ c! ( $ r" dst-adr ) + r> 1+ ( $ dst-adr' ) +; + +6 buffer: temp-mac-address +: decode-enaddr ( adr len -- adr' len' ) \ ASCII to binary + push-hex + temp-mac-address 6 0 do decode-ether-byte loop drop + pop-base + temp-mac-address 6 +; + +6 actions +action: ( apf -- adr len ) cv-bytes@ ; +action: ( adr len apf -- ) cv-bytes! ; +action: ( apf -- adr ) cv-adr drop ; +action: ( adr len apf -- adr len ) drop encode-enaddr ; +action: ( adr len apf -- adr len ) drop decode-enaddr ; +action: ( apf -- adr len ) la1+ dup la1+ swap @ ; + +\ e.g. keymap +: config-mac-address ( "name" default-value-adr len maxlen -- ) + config-create use-actions drop ( adr len ) + dup , + dup taligned here swap note-string allot ( adr len here ) + swap move +; + +" " 6 config-mac-address mfg-mac-address + +' mfg-mac-address to system-mac-address + +0 [if] +8 buffer: mac-address-buf +: random-mac-address ( -- adr len ) + mac-address-buf @ 0= if + \ Get a pseudo-random number + + \ Seed it with the real time clock and the timestamp counter + time&date xor xor xor xor xor ( seed ) + tsc@ xor xor ( seed' ) + + \ Scramble it a bit with a linear congruence + d# 1103515245 * d# 12345 + h# 7FFFFFFF and ( rn1 ) + dup mac-address-buf ! ( rn1 ) + d# 1103515245 * d# 12345 + h# 7FFFFFFF and ( rn2 ) + mac-address-buf 3 + ! ( ) + + \ Turn off the multicast bit and turn on the locally-assigned bit + mac-address-buf c@ h# fe and 2 or mac-address-buf c! + then + + mac-address-buf 6 +; +' random-mac-address to system-mac-address +[then] + + +\ LICENSE_BEGIN +\ Copyright (c) 2008 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
