Author: wmb Date: 2009-12-12 04:15:55 +0100 (Sat, 12 Dec 2009) New Revision: 1587
Modified: cpu/x86/pc/olpc/via/runin.fth Log: Checked in some bug fixes to runin.fth found in code walkthrough.
Modified: cpu/x86/pc/olpc/via/runin.fth =================================================================== --- cpu/x86/pc/olpc/via/runin.fth 2009-12-12 02:49:14 UTC (rev 1586) +++ cpu/x86/pc/olpc/via/runin.fth 2009-12-12 03:15:55 UTC (rev 1587) @@ -35,7 +35,7 @@ d# 11 sn-buf c! ;
-: get-sn ( -- ) +: scan-sn ( -- ) ." *****"
begin @@ -50,14 +50,16 @@ ;
: get-info ( -- ) - get-sn + scan-sn ;
0 0 2value response$
+: final-filename$ ( -- adr len ) board#$ " %s.txt" ; + \ Send the board number as the request and return the response data : final-tag-exchange ( -- ) - board#$ " %s.txt" open-temp-file + final-filename$ open-temp-file sn$ " SN:" put-key+value " Request" submit-file " Response" get-response to response$ @@ -118,6 +120,10 @@ : show-tag ( value$ -- ) tag-printable? if ?-null type else wrapped-cdump then ; +: do-tag-error ( -- ) + \ Don't know what to do here + begin halt again +; : handle-tag ( value$ key$ -- ) 2dup find-tag if ( value$ key$ old-value$ ) \ Tag already exists, check it 2over " KA" $= 0= if ?-null then ( value$ key$ old-value$' ) @@ -127,6 +133,7 @@ type ." tag changed!" cr ( value$ r: old-value$' ) ." Old: " r> show-tag cr ( value$ ) ." New: " show-tag cr ( ) + do-tag-error then else ( value$ key$ ) \ New tag, add it put-tag @@ -248,7 +255,7 @@
\ Upload the result data : final-result ( -- ) - smt-filename$ open-temp-file + final-filename$ open-temp-file upload-tags test-passed? if " PASS" else " FAIL" then " RESULT=" put-key+value " Result" submit-file @@ -278,6 +285,7 @@ cifs-connect final-result cifs-disconnect \ " int:\runin\olpc.fth" $delete-all
+ \ Ultimately this should just be delete of runin\olpc.fth " int:\runin\olpc.fth" " int:\runin\final.fth" $rename
." Powering off ..." d# 2000 ms
