Author: wmb Date: Fri Aug 3 23:23:39 2012 New Revision: 3129 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3129
Log: Debugger - added longer stack display to visual mode.
Modified: forth/lib/debug.fth
Modified: forth/lib/debug.fth ============================================================================== --- forth/lib/debug.fth Fri Aug 3 23:10:03 2012 (r3128) +++ forth/lib/debug.fth Fri Aug 3 23:23:39 2012 (r3129) @@ -126,17 +126,27 @@ 0 value stack-line d# 45 constant stack-column \ 0 0 2value result-loc +0 0 2value full-stack-xy 0 value result-line 0 value result-col : to-stack-location ( -- ) stack-column stack-line at-xy kill-line ; +: show-full-stack ( -- ) + full-stack-xy at-xy kill-line + depth 0< if ." Stack Underflow" exit then \ Don't clear stack here + depth 0= if ." Empty" exit then + depth 7 > if ." .. " then + depth depth 7 - 0 max ?do depth i - 1- pick n. loop +; : show-partial-stack ( -- ) + show-full-stack + to-stack-location
." \ " depth 0< if ." Stack Underflow" sp0 @ sp! exit then depth 0= if ." Empty" exit then - depth 4 > if ." .. " then - depth depth 5 - 0 max ?do depth i - 1- pick n. loop + depth 3 > if ." .. " then + depth depth 4 - 0 max ?do depth i - 1- pick n. loop ;
\ : save-result-loc ( -- ) #out @ #line @ to result-loc ; @@ -191,6 +201,7 @@ d# 70 rmargin ! ." Callers: " rp0 @ the-rp na1+ rslist kill-line cr d# 40 rmargin ! + ." Stack: " #out @ #line @ to full-stack-xy cr \ For stack the-ip debug-see cr \ Display the initial stack on the cursor line
