Author: quozl Date: Mon Sep 10 10:39:51 2012 New Revision: 3300 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3300
Log: OLPC XO-4 B1 - add new SPI FLASH ID 35 for MXIC 25U1635E
Modified: dev/olpc/spiflash/spiflash.fth
Modified: dev/olpc/spiflash/spiflash.fth ============================================================================== --- dev/olpc/spiflash/spiflash.fth Fri Sep 7 10:39:55 2012 (r3299) +++ dev/olpc/spiflash/spiflash.fth Mon Sep 10 10:39:51 2012 (r3300) @@ -308,7 +308,8 @@ h# 13 of ['] common-write endof h# 34 of ['] common-write endof h# bf of ['] sst-write endof - h# 14 of ['] common-write endof + h# 14 of ['] common-write endof + h# 35 of ['] common-write endof \ On some old board the ID would read as 14 when it should have been something else. \ On CL4, 14 is the expected ID. \ ." The SPI FLASH ID reads as 14. This is due to an infrequent hardware problem." cr
