Author: wmb Date: Fri Dec 3 07:55:12 2010 New Revision: 2064 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2064
Log: XO-1.75 - compile NANDblaster support into Forth dictionary (but NB object code is not yet in the build).
Modified: cpu/arm/olpc/1.75/devices.fth cpu/arm/olpc/1.75/fw.bth
Modified: cpu/arm/olpc/1.75/devices.fth ============================================================================== --- cpu/arm/olpc/1.75/devices.fth Fri Dec 3 07:37:40 2010 (r2063) +++ cpu/arm/olpc/1.75/devices.fth Fri Dec 3 07:55:12 2010 (r2064) @@ -245,6 +245,8 @@
end-package
+: wlan-reset ( -- ) d# 58 gpio-clr d# 20 ms d# 58 gpio-set ; + \ : usb-power-on ( -- ) 1 gpio-set ; : usb-power-on ( -- ) ; \ The EC controls the USB power : reset-usb-hub ( -- ) d# 146 gpio-set d# 10 ms d# 146 gpio-set ;
Modified: cpu/arm/olpc/1.75/fw.bth ============================================================================== --- cpu/arm/olpc/1.75/fw.bth Fri Dec 3 07:37:40 2010 (r2063) +++ cpu/arm/olpc/1.75/fw.bth Fri Dec 3 07:55:12 2010 (r2064) @@ -193,18 +193,15 @@ ; ' pre-setup-for-linux to linux-pre-hook
-[ifdef] notyet +: show-temperature ( -- ) ; +: boot-as-call( ( -- ) ." Implement boot-as-call" cr ; +: )boot-as-call ( -- ) ; +\ fload ${BP}/cpu/x86/bootascall.fth create use-thinmac -fload ${BP}/cpu/x86/bootascall.fth fload ${BP}/cpu/x86/pc/olpc/wifichannel.fth fload ${BP}/cpu/x86/pc/olpc/via/nbtx.fth fload ${BP}/cpu/x86/pc/olpc/via/nbrx.fth fload ${BP}/cpu/x86/pc/olpc/via/blockfifo.fth -[else] -0 value nb-zd-#sectors -: nandblaster true abort" No nandblaster yet" ; -: show-temperature ; -[then]
: hdd-led-off ( -- ) d# 10 gpio-clr ; : hdd-led-on ( -- ) d# 10 gpio-set ;
