Author: quozl Date: Tue Sep 18 05:27:06 2012 New Revision: 3313 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3313
Log: OLPC XO-4 - Neonode, do not process fixed signal strength response packets unless they are present, probably fixes a Data Abort when the controller ceases to respond.
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Mon Sep 17 09:39:42 2012 (r3312) +++ cpu/arm/olpc/nn-touchscreen.fth Tue Sep 18 05:27:06 2012 (r3313) @@ -22,11 +22,10 @@
\ create nn-fss \ optional fixed signal strength test \ create nn-ls \ optional low signals test +\ create nn-fss-all \ fixed signal strength test, all power levels
\ create nn-components \ isolate test results to failed component identifier
-\ create nn-ir-pcb-rev-b \ support for revision b of the ir pcb assembly - d# 15 value xleds d# 11 value yleds
@@ -455,10 +454,12 @@ : test-fss-axis-all ( axis power -- ) swap h# 0f h# 03 h# ee 5 bytes-out h# 0f d# 20 anticipate - pbuf 4 + c@ 0 do ( ) - pbuf 5 + i + c@ - .d - loop cr + pbuf 2+ c@ h# 0f = if + pbuf 4 + c@ 0 do ( ) + pbuf 5 + i + c@ + .d + loop cr + then ;
: test-fss-all @@ -480,14 +481,16 @@ h# 0f h# 03 h# ee 5 bytes-out ( r: power ) h# 0f d# 20 anticipate r> ( power) - pbuf 4 + c@ 0 do ( power ) - pbuf 5 + i + c@ ( power signal ) - over swap ( power x y ) - >scaled - - i 4 lshift >pseudo -rot 9 9 ( color x y w h ) - fill-rectangle-noff ( ) - loop ( power ) + pbuf 2+ c@ h# 0f = if + pbuf 4 + c@ 0 do ( power ) + pbuf 5 + i + c@ ( power signal ) + over swap ( power x y ) + >scaled + + i 4 lshift >pseudo -rot 9 9 ( color x y w h ) + fill-rectangle-noff ( ) + loop ( power ) + then ( power ) drop ;
@@ -693,11 +696,12 @@ dup to axis# ( axis# ) fs swap h# 0f h# 03 h# ee 5 bytes-out h# 0f d# 200 anticipate - - pbuf 4 + c@ 0 do ( ) - i pbuf 5 + over + c@ ( signal# level ) - watch-fss-signal ( ) - loop + pbuf 2+ c@ h# 0f = if + pbuf 4 + c@ 0 do ( ) + i pbuf 5 + over + c@ ( signal# level ) + watch-fss-signal ( ) + loop + then ;
: watch-fss
