Author: quozl Date: Wed Sep 5 02:59:42 2012 New Revision: 3284 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3284
Log: OLPC XO-4 - Neonode, complete Lightguide Tooling test
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Wed Sep 5 01:46:39 2012 (r3283) +++ cpu/arm/olpc/nn-touchscreen.fth Wed Sep 5 02:59:42 2012 (r3284) @@ -691,6 +691,11 @@ ;
+: lg-tooling ( -- error? ) + open if test-os test-fll else fault then + faults +; + : ir-pcb-smt ( -- error? ) hold-reset connect open if test-os else fault then @@ -732,6 +737,7 @@ h# 2 of mb-assy exit endof h# 11 of ir-pcb-smt exit endof h# 12 of ir-pcb-assy exit endof + h# 13 of lg-tooling exit endof endcase
\ MB FINAL @@ -765,18 +771,21 @@
: test-pass-or-fail ( function -- error? ) catch if - show-fail + show-fail true else - show-pass + show-pass false then ;
-: test-ir-pcb-assy ( -- error? ) - test-station h# 12 to test-station ( test-station ) +\ touch screen (test by) test station +: tsts ( test-station -- error? ) + test-station swap to test-station ( test-station ) ['] test-touchscreen test-pass-or-fail ( test-station error? ) swap to test-station ( error? ) ;
+: test-ir-pcb-assy ( -- error? ) h# 12 tsts ; +: test-lightguide ( -- error? ) h# 13 tsts ;
\ LICENSE_BEGIN \ Copyright (c) 2012 FirmWorks
