Author: wmb Date: Wed Nov 24 21:29:04 2010 New Revision: 2035 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2035
Log: Changed ps2mouse.fth to use my-space instead of my-unit for set-port; my-unit does not work right.
Modified: dev/ps2mouse.fth
Modified: dev/ps2mouse.fth ============================================================================== --- dev/ps2mouse.fth Tue Nov 23 23:37:52 2010 (r2034) +++ dev/ps2mouse.fth Wed Nov 24 21:29:04 2010 (r2035) @@ -299,7 +299,7 @@ lock[ identify if \ This port is unresponsive; try the other - my-unit 1- set-port identify if ]unlock true exit then + my-space 1- set-port identify if ]unlock true exit then then ( id )
dup h# ab = if ( id ) @@ -312,7 +312,7 @@ my-port 0= if ]unlock true exit then
\ Otherwise look for the mouse on the keyboard port - my-unit 1- set-port identify if ]unlock true exit then ( id ) + my-space 1- set-port identify if ]unlock true exit then ( id ) then ( id ) ]unlock ( id )
@@ -325,7 +325,7 @@
headers : open ( -- flag ) - my-unit set-port + my-space set-port
open-count 0= if \ The "force" argument causes the open to succeed even if no mouse
