Author: wmb Date: 2009-09-10 10:04:30 +0200 (Thu, 10 Sep 2009) New Revision: 1355
Modified: cpu/x86/pc/olpc/via/devices.fth cpu/x86/pc/olpc/via/fw.bth Log: Via - fixed fsdisk and net aliases for use with fs-update
Modified: cpu/x86/pc/olpc/via/devices.fth =================================================================== --- cpu/x86/pc/olpc/via/devices.fth 2009-09-10 08:02:28 UTC (rev 1354) +++ cpu/x86/pc/olpc/via/devices.fth 2009-09-10 08:04:30 UTC (rev 1355) @@ -364,6 +364,18 @@ " usb-keyboard" " /usb@10,4/keyboard" ?report-device \ USB 2 (keyboard behind a hub) ;
+\ If there is a USB ethernet adapter, use it as the default net device. +\ We can't use ?report-device here because we already have net aliased +\ to /usb/wlan, and ?report-device won't override an existing alias. +: report-net ( -- ) + " /usb/ethernet" 2dup locate-device 0= if ( name$ phandle ) + drop ( name$ ) + " net" 2swap $devalias ( ) + else ( name$ ) + 2drop ( ) + then +; + [ifdef] Later \ Add support for DC-couple microphone input [then]
Modified: cpu/x86/pc/olpc/via/fw.bth =================================================================== --- cpu/x86/pc/olpc/via/fw.bth 2009-09-10 08:02:28 UTC (rev 1354) +++ cpu/x86/pc/olpc/via/fw.bth 2009-09-10 08:04:30 UTC (rev 1355) @@ -470,7 +470,7 @@ fload ${BP}/cpu/x86/pc/olpc/wifichannel.fth [then] fload ${BP}/cpu/x86/pc/olpc/via/fsupdate.fth -devalias fsdisk /sd/disk:0 +devalias fsdisk int:0
fload ${BP}/ofw/inet/sntp.fth : olpc-ntp-servers ( -- ) @@ -641,8 +641,6 @@ ['] false to interrupt-auto-boot? probe-usb " probe+" do-drop-in - report-disk - report-keyboard
setup-smbios \ Must be done after build-date is defined via do-drop-in
