Author: wmb Date: Thu Aug 9 03:49:54 2012 New Revision: 3140 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3140
Log: OLPC ARM - Checked in swhash.fth
Added: cpu/arm/olpc/swhash.fth
Added: cpu/arm/olpc/swhash.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/olpc/swhash.fth Thu Aug 9 03:49:54 2012 (r3140) @@ -0,0 +1,45 @@ +: sha1 ( data$ -- hash$ ) load-crypto throw " sha1" crypto-hash ; +: sha-256 ( data$ -- hash$ ) load-crypto throw " sha256" crypto-hash ; +: md5 ( data$ -- hash$ ) load-crypto throw " md5" crypto-hash ; + +: convert-crypto-args ( data$n..data$1 n -- 0 data$n..data$1 ) + \ signature-bad? wants the end of data to be marked by a 0 length + \ so we move the n data strings to the return stack, push a 0, + \ then move the strings back. We can't use do..loop because it + \ interferes with the return stack. + dup ( data$n..data$1 n rem ) + begin dup while ( data$n..data$1 n rem ) + 2swap 2>r ( data$n..data$m n rem r: data$ .. ) + 1- ( data$n..data$m n rem' r: data$ .. ) + repeat ( n 0 r: data$ .. ) + drop ( n r: data$ .. ) + + 0 swap ( 0 n r: data$ .. ) + begin dup while ( rem r: data$ .. ) + 2r> rot ( 0 data$n .. rem r: data$ .. ) + 1- ( 0 data$n .. rem' r: data$ .. ) + repeat ( 0 data$n.. 0 r: data$ .. ) + drop ( 0 data$n..data$1 ) +; + +d# 128 buffer: hashbuf +: hash-n ( data$n..data$1 n hashname$ -- result$ ) + load-crypto throw + 2>r ( data$n..data$1 n r: hashname$ ) + + convert-crypto-args ( 0 data$n..data$1 r: hashname$ ) + + \ The 0 above hashlen tells the crypto function to perform the hash + \ only, without signature checking, returning the length of the + \ hash result in hashlen. + hashbuf d# 128 hashlen 0 2r> ( 0 data$.. sig$ key$ hashname$ ) + + signature-bad? h# fffff and abort" Hash failed" ( ) + hashbuf hashlen @ +; + +\ For use by hmacsha1 in the wifi supplicant package +d# 20 constant /sha1-digest +alias sha1-digest hashbuf + +: sha1-n ( data$n..data$1 n -- digest$ ) " sha1" hash-n ;
