Author: wmb Date: 2009-09-10 10:07:14 +0200 (Thu, 10 Sep 2009) New Revision: 1356
Modified: cpu/x86/pc/olpc/via/romreset.bth cpu/x86/pc/olpc/via/startcominit.fth Log: Via early startup - 1) Fixed version sensing via EC - needed to enable I/O decoding for the special EC port 2) Moved the startup delay to exactly the required point, just before the first CMOS access 3) Restore a couple of registers in D17F7 that are killed during S3.
Modified: cpu/x86/pc/olpc/via/romreset.bth =================================================================== --- cpu/x86/pc/olpc/via/romreset.bth 2009-09-10 08:04:30 UTC (rev 1355) +++ cpu/x86/pc/olpc/via/romreset.bth 2009-09-10 08:07:14 UTC (rev 1356) @@ -92,8 +92,6 @@
fload ${BP}/cpu/x86/pc/olpc/via/startcacheasram.fth
- d# 40000 wait-us \ This delay is empirically necessary - minimum is 36000 - about 50 ms - \ cache_as_ram_auto.c: amd64_main()
01 004f config-wb \ Enable device 0 multiple functions @@ -114,8 +112,6 @@ cominit #) call [then]
- carret report - linefeed report char + report h# 1d port80
@@ -127,17 +123,24 @@ long-offsets on
acpi-io-base 4 + port-rw \ Get APCI Status register - d# 10 # ax shr 7 # ax and 1 # ax cmp <> if \ Wakeup from S3 + d# 10 # ax shr 7 # ax and 1 # ax cmp <> if \ Type 1 is wakeup from S3 + \ Not wakeup from S3 \ This turns an OS reboot into a real cold start - from coreboot h# 380 config-rb ax ax or 0<> if \ C-page shadowing not on yet 6 h# cf9 port-wb \ Force a full system reset char X report begin hlt again then + carret report linefeed report char F report fload ${BP}/cpu/x86/pc/olpc/via/demodram.fth then
+ \ This must be done in both the power-up and resume-from-S3 cases, + \ since the registers in D17F7 lose state during S3. + total-size 8f60 config-wb \ DRAM Bank 7 ending address - controls DMA upstream + 0388 config-rb ax bx mov 8fe5 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to SB Low Top e5 + fload ${BP}/cpu/x86/pc/olpc/via/startgfxinit.fth
0 [if] \ Fire up C Forth @@ -171,6 +174,10 @@ fload ${BP}/cpu/x86/pc/olpc/via/ioinit.fth \ XXX need to move startcpuspeed to here
+ \ Cache is now setup normally, backed by memory + \ Setup a small stack for subroutine calls + h# 10.0000 # esp mov + acpi-io-base 4 + port-rw \ Get APCI Status register ax bx mov d# 10 # ax shr 7 # ax and 1 # ax cmp = if \ Wakeup from S3 @@ -192,9 +199,6 @@ char x report then \ Not a wakeup from S3
- \ Cache is now setup normally, backed by memory - h# 20.0000 # esp mov - char o report h# 1e port80
Modified: cpu/x86/pc/olpc/via/startcominit.fth =================================================================== --- cpu/x86/pc/olpc/via/startcominit.fth 2009-09-10 08:04:30 UTC (rev 1355) +++ cpu/x86/pc/olpc/via/startcominit.fth 2009-09-10 08:07:14 UTC (rev 1356) @@ -34,6 +34,24 @@ 4e 18 18 mreg \ Enable ports 74/75 for CMOS RAM access - 10 res be like Phx end-table
+ \ Configure the I/O decoding to enable access to the EC + \ Do this outside the if..then so the setup is consistent in all cases + d# 17 0 devfunc + 59 ff 1c mreg \ Keyboard (ports 60,64) and ports 62,66 on LPC bus (EC) + 5c ff 68 mreg \ High byte (68) of PCS0 + 5d ff 00 mreg \ High byte (00) of PCS0 + 64 0f 07 mreg \ PCS0 size is 8 bytes - to include 68 and 6c + 66 01 01 mreg \ PCS0 Enable + 67 10 10 mreg \ PCS0 to LPC Bus + end-table + + \ This delay is empirically necessary before reading CMOS - minimum is 36000 - about 50 ms + \ Before the delay has elapsed, the CMOS RAM returns 0 instead of the stored value. + d# 40000 wait-us + + \ As an optimization to avoid long waits for the EC to respond, read the board ID + \ that is cached in CMOS RAM. This might not in fact be an optimization in light + \ of the above delay ... h# 83 # al mov al h# 74 # out h# 75 # al in \ check byte - should be ~board-id al ah mov ah not \ ~check byte in AH h# 82 # al mov al h# 74 # out h# 75 # al in \ board-id in AL
