Author: wmb Date: Thu Feb 3 02:00:19 2011 New Revision: 2162 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2162
Log: OLPC XO-1.75 - Added a device node for the Marvell Armada 610 TWSI hardware.
Modified: cpu/arm/mmp2/twsi.fth
Modified: cpu/arm/mmp2/twsi.fth ============================================================================== --- cpu/arm/mmp2/twsi.fth Thu Feb 3 01:59:11 2011 (r2161) +++ cpu/arm/mmp2/twsi.fth Thu Feb 3 02:00:19 2011 (r2162) @@ -91,41 +91,32 @@
: twsi-get ( register-address .. #reg-bytes #data-bytes -- data-byte ... ) >r ( reg-adr .. #regs r: #data-bytes ) - \ Handle the case where the device does not require that a write register address be sent - slave-address ( reg-adr .. #regs slave-address r: #data-bytes ) - over 0= if ( reg-adr .. #regs slave-address r: #data-bytes ) - r@ if ( reg-adr .. #regs slave-address r: #data-bytes ) - 1 or ( reg-adr .. #regs slave-address' r: #data-bytes ) - then ( reg-adr .. #regs slave-address' r: #data-bytes ) - then ( reg-adr .. #regs slave-address' r: #data-bytes ) - - twsi-start ( reg-adr .. #regs r: #data-bytes ) - - \ Abort the transaction if both #reg-bytes and #data-bytes are 0 - dup r@ or 0= if ( #regs r: #data-bytes ) - iue+scle bbu_ICR_MA or cr! ( #regs r: #data-bytes ) \ Master abort - r> 2drop exit ( -- ) - then ( reg-adr .. #regs r: #data-bytes ) - - \ Send register addresses, if any - 0 ?do 0 twsi-putbyte loop ( r: #data-bytes ) - - \ If no result data requested, quit now - r> dup 0= if ( #data-bytes ) - drop ( ) - iue+scle bbu_ICR_STOP or cr! ( ) - exit - then ( #data-bytes ) - - \ Otherwise send the read address with another start bit - slave-address 1 or bbu_ICR_START twsi-putbyte ( #data-bytes ) - sr@ sr! \ clear ITE and IRF status bits ( #data-bytes ) - \ Bug on line 367 of bbu_TWSI.s - writes SR without first reading it - - 1- 0 ?do 0 twsi-getbyte loop ( bytes ) - - \ Set the stop bit on the final byte - bbu_ICR_STOP bbu_ICR_ACKNAK or twsi-getbyte ( bytes ) + ?dup if ( reg-adr .. #regs slave-address r: #data-bytes ) + slave-address ( reg-adr .. #regs slave-address r: #data-bytes ) + twsi-start ( reg-adr .. #regs r: #data-bytes ) + + \ Send register addresses + 0 ?do 0 twsi-putbyte loop ( r: #data-bytes ) + + \ If no result data requested, quit now + r@ 0= if ( r: #data-bytes ) + r> drop ( ) + iue+scle bbu_ICR_STOP or cr! ( ) + exit + then ( r: #data-bytes ) + then ( r: #data-bytes ) + + r> ?dup if ( #data-bytes ) + \ Send the read address with a (or another) start bit + slave-address 1 or bbu_ICR_START twsi-putbyte ( #data-bytes ) + sr@ sr! \ clear ITE and IRF status bits ( #data-bytes ) + \ Bug on line 367 of bbu_TWSI.s - writes SR without first reading it + + 1- 0 ?do 0 twsi-getbyte loop ( bytes ) + + \ Set the stop bit on the final byte + bbu_ICR_STOP bbu_ICR_ACKNAK or twsi-getbyte ( bytes ) + then ;
: twsi-write ( byte .. #bytes -- ) @@ -137,3 +128,20 @@
: twsi-b@ ( reg -- byte ) 1 1 twsi-get ; : twsi-b! ( byte reg -- ) 2 twsi-write ; + +0 0 " " " /" begin-package +" twsi" name + +0 0 instance 2value child-address +: open ( -- okay? ) true ; +: close ( -- ) ; +: set-address ( target channel -- ) to child-address ; +2 " #address-cells" integer-property +0 " #size-cells" integer-property +: get ( #bytes -- bytes ... ) + child-address set-twsi-target + 0 swap twsi-get +; +: decode-unit ( adr len -- low high ) parse-2int ; +: encode-unit ( low high -- adr len ) >r <# u#s drop [char] , hold r> u#s u#> ; +end-package
