Author: quozl Date: Wed Sep 12 08:06:31 2012 New Revision: 3302 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3302
Log: OLPC XO-4 - Neonode, use a red-yellow-green pseudocolour map for watch-fss and watch-fll, leave the greyscale mode available for visually challenged
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Mon Sep 10 13:33:13 2012 (r3301) +++ cpu/arm/olpc/nn-touchscreen.fth Wed Sep 12 08:06:31 2012 (r3302) @@ -544,10 +544,15 @@ fill-rectangle-noff ( ) ;
-: level>colour ( signal-value -- colour ) - d# 3 rshift dup d# 5 lshift over d# 11 lshift or or +: >grey ( level -- colour ) dup dup rgb>565 ; + +: >pseudo ( level -- colour ) \ a red-yellow-green pseudocolour bar + d# 256 over - 2* d# 255 min swap 2* d# 255 min 0 rgb>565 ;
+defer level>rgb +' >pseudo is level>rgb + : ys>xy ( signal# -- x y ) yx swap ( x signal# ) screen-h yleds 2* / * ( x y ) @@ -569,7 +574,7 @@ 0 value axis#
: draw-signal ( signal# level -- x y ) - level>colour pixcolor ! ( signal# ) + level>rgb pixcolor ! ( signal# ) axis# if ( signal# ) \ y ys>xy else ( signal# ) \ x
