Author: wmb Date: Fri Nov 2 21:08:05 2012 New Revision: 3407 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3407
Log: OLPC XO-4 - Trac #12169 - Isolate eMMC pins to avoid back-driving the eMMC voltage rail from the signal lines.
Modified: cpu/arm/olpc/sdhci.fth
Modified: cpu/arm/olpc/sdhci.fth ============================================================================== --- cpu/arm/olpc/sdhci.fth Thu Nov 1 22:02:34 2012 (r3406) +++ cpu/arm/olpc/sdhci.fth Fri Nov 2 21:08:05 2012 (r3407) @@ -21,21 +21,54 @@ ; ' olpc-card-inserted? to card-inserted?
+[ifdef] olpc-cl4 +also forth definitions +: isolate-mmc3-pins ( gpio# #gpios -- ) + bounds do + i af@ 7 invert and 1 or i af! + i gpio-dir-out i gpio-clr + loop +; +: connect-mmc3-pins ( gpio# #gpios -- ) + bounds do + i af@ 7 invert and 2 or i af! + loop +; +: isolate-emmc ( -- ) + d# 108 4 isolate-mmc3-pins + d# 161 4 isolate-mmc3-pins + d# 145 2 isolate-mmc3-pins +; +: connect-emmc ( -- ) + d# 108 4 connect-mmc3-pins + d# 161 4 connect-mmc3-pins + d# 145 2 connect-mmc3-pins +; +previous definitions +[then] + \ Base-addr:power_GPIO - 1:35, 2:34, 3:33 : gpio-power-on ( -- ) sdhci-card-power-on [ifdef] en-emmc-pwr-gpio# - base-addr h# d428.1000 = if en-emmc-pwr-gpio# gpio-clr then + base-addr h# d428.1000 = if + [ifdef] connect-emmc connect-emmc [then] + en-emmc-pwr-gpio# gpio-clr + then [then] [ifdef] en-wlan-pwr-gpio# base-addr h# d428.0800 = if en-wlan-pwr-gpio# gpio-set then [then] +[then] ; ' gpio-power-on to card-power-on
: gpio-power-off ( -- ) [ifdef] en-emmc-pwr-gpio# - base-addr h# d428.1000 = if en-emmc-pwr-gpio# gpio-set then + base-addr h# d428.1000 = if + en-emmc-pwr-gpio# gpio-set + [ifdef] isolate-emmc isolate-emmc [then] + then [then] [ifdef] en-wlan-pwr-gpio# base-addr h# d428.0800 = if en-wlan-pwr-gpio# gpio-clr then
