Author: wmb Date: 2009-08-01 20:16:45 +0200 (Sat, 01 Aug 2009) New Revision: 1268
Added: cpu/x86/iirfilter.fth Log: First cut at IIR upsampling filter.
Added: cpu/x86/iirfilter.fth =================================================================== --- cpu/x86/iirfilter.fth (rev 0) +++ cpu/x86/iirfilter.fth 2009-08-01 18:16:45 UTC (rev 1268) @@ -0,0 +1,63 @@ +purpose: IIR digital filter support + +\ iir-cascade implements the "Folded Cascade First Order Filters" +\ structure as shown on page 274 of _Multirate Signal Processing +\ for Communications Systems_ by fredric j harris, Prentice Hall 2004 +\ ISBN 0-13-146511-2 + +code iir-cascade ( sample weights z #coefs -- out ) + cx pop \ CX: Number of coefficients + + bp bx mov \ Save + bp pop \ BP: Z list + si dx mov \ Save SI + si pop \ SI: Filter weights + ax pop \ AX: current value + dx push \ Saved SI on stack + bx push \ Saved BP on stack + begin + ax bx mov \ Save last value + 4 [bp] ax sub \ last - M[i+1] + 0 [si] ax imul \ alpha[i] * (last - M[i+1]) (kills DX) + 4 [si] si lea \ Increment alpha pointer + d# 14 # ax shr \ Scale down by multiplier scale factor + 0 [bp] ax add \ M[i] + alpha[i] * (last - M[i+1]) + bx 0 [bp] mov \ Update M[i] + 4 [bp] bp lea \ Point to next M[i] + loopa + + bp pop \ Restore BP + si pop \ Restore SI + ax push \ Return value +c; + +\ upsample by 4 + +2 constant #coefs + +create weights0 mul14: .101467517 mul14: .612422841 +create weights1 mul14: .342095596 mul14: .867647439 + +#coefs 1+ /n* constant buflen +buflen buffer: z0 +buflen buffer: z1 +buflen buffer: z2 +buflen buffer: z3 + +: init-upsample + z0 buflen erase + z1 buflen erase + z2 buflen erase + z3 buflen erase +; + +0 [if] +for each input sample + sample weights0 z0 #coefs iir-cascade dup to int0 ( out0 ) int1 + + dup weights0 z2 #coefs iir-cascade dup to out0 out1 + ,next-output + weights1 z3 #coefs iir-cascade dup to out1 out0 + ,next-output + + sample weights0 z1 #coefs iir-cascade dup to int1 ( out1 ) int0 + + dup weights0 z2 #coefs iir-cascade dup to out0 out1 + ,next-output + weights1 z3 #coefs iir-cascade dup to out1 out0 + ,next-output +[then]
