Author: quozl Date: Wed Nov 14 04:06:40 2012 New Revision: 3422 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3422
Log: OLPC XO-1.75 - remove BSL support, was used for prototyping
Modified: cpu/arm/olpc/1.75/fw.bth
Modified: cpu/arm/olpc/1.75/fw.bth ============================================================================== --- cpu/arm/olpc/1.75/fw.bth Wed Nov 14 00:10:08 2012 (r3421) +++ cpu/arm/olpc/1.75/fw.bth Wed Nov 14 04:06:40 2012 (r3422) @@ -7,9 +7,6 @@
" fw.tag" r/w create-file drop tag-file !
-h# 17000 +io constant bsl-uart-base \ UART2 -h# 30 constant bsl-uart-clock-offset \ APBC_UART2_CLK_RST - fload ${BP}/cpu/arm/olpc/build-fw.fth
\ The internal SD card shares the host controller circuitry with
