Author: wmb Date: Tue Dec 6 08:10:34 2011 New Revision: 2734 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2734
Log: OLPC XO-3 - USB SPH / ULPI PHY now working.
Added: cpu/arm/mmp2/ulpiphy.fth Modified: cpu/arm/olpc/3.0/usb.fth
Added: cpu/arm/mmp2/ulpiphy.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/mmp2/ulpiphy.fth Tue Dec 6 08:10:34 2011 (r2734) @@ -0,0 +1,38 @@ +\ See license at end of file +purpose: Access to miscellaneous control/enable registers for the ULPI PHY portion of the USB SPH controller + +h# 3800 io2-va + constant usbsph-misc-va +: usbsph-misc@ ( -- n ) usbsph-misc-va 4 + l@ ; +: usbsph-misc! ( n -- ) usbsph-misc-va 4 + l! ; +: usbsph-int@ ( -- n ) usbsph-misc-va h# 28 + l@ ; +: usbsph-int! ( n -- ) usbsph-misc-va h# 28 + l! ; +: usbsph-ctrl@ ( -- n ) usbsph-misc-va h# 30 + l@ ; +: usbsph-ctrl! ( n -- ) usbsph-misc-va h# 30 + l! ; +: ulpi-on ( -- ) h# 0800.0000 usbsph-misc! ; +: ulpi-resume-interrupt-on ( -- ) 2 usbsph-int! ; +: ulpi-clock-on ( -- ) usbsph-ctrl@ 1 or usbsph-ctrl! ; +: ulpi-clock-select ( -- ) usbsph-ctrl@ h# 400 or usbsph-ctrl! ; + +\ LICENSE_BEGIN +\ Copyright (c) 2011 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Modified: cpu/arm/olpc/3.0/usb.fth ============================================================================== --- cpu/arm/olpc/3.0/usb.fth Tue Dec 6 08:10:23 2011 (r2733) +++ cpu/arm/olpc/3.0/usb.fth Tue Dec 6 08:10:34 2011 (r2734) @@ -20,7 +20,7 @@ : wake ( -- ) ; end-package
-0 0 " f0001000" " /" begin-package \ USB Host Controller 1 - ULPI +0 0 " f0003000" " /" begin-package \ USB Host Controller 1 - ULPI h# 200 constant /regs my-address my-space /regs reg : my-map-in ( len -- adr ) @@ -44,6 +44,9 @@ ; : reset-usb-hub ( -- ) d# 146 gpio-clr d# 10 ms d# 146 gpio-set \ Resets ULPI hub + ulpi-clock-on + ulpi-clock-select + ulpi-on ;
: init-usb ( -- )
