Author: quozl Date: Wed Mar 13 06:17:36 2013 New Revision: 3606 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3606
Log: OLPC XO-4 - touchscreen test, nonlinearity test, add targets, remove guide line, begin recording when target hit, stop recording when next target hit, tune minimum points, span, stride, and threshold. Remove test from menu, access only via select /touchscreen, test-nonlinearity.
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Wed Mar 13 06:09:24 2013 (r3605) +++ cpu/arm/olpc/nn-touchscreen.fth Wed Mar 13 06:17:36 2013 (r3606) @@ -900,8 +900,6 @@ until drop ( ) ;
-d# 50 value #skip \ Number of initial points to ignore for line -0 value skipping? \ Current skip count : ev( configure cursor-off @@ -910,7 +908,6 @@ blacken .tsmsg -1 to remaining - #skip to skipping? ;
: )ev @@ -925,6 +922,10 @@
\ Nonlinearity test
+d# 50 value #skip \ Number of initial points to ignore for line +0 value skipping? \ Current skip count +0 value starting? + d# 2000 constant #pts-max
#pts-max /w* value /buf @@ -932,6 +933,37 @@ 0 value ybuf 0 value #pts
+h# 80 value target-size + +: draw-start ( colour -- ) + 0 screen-h target-size - target-size dup fill-rectangle-noff +; + +: draw-stop ( colour -- ) + screen-w target-size - 0 target-size dup fill-rectangle-noff +; + +: in-start? ( x y -- flag ) + screen-h target-size - screen-h between + swap + 0 target-size between + and + dup if blue draw-start then +; + +: in-stop? ( x y -- flag ) + 0 target-size between + swap + screen-w target-size - screen-w between + and + dup if blue draw-stop then +; + +: draw-targets ( -- ) + green draw-start + red draw-stop +; + : alloc-bufs ( -- ) /buf alloc-mem to xbuf /buf alloc-mem to ybuf @@ -1031,8 +1063,13 @@ swap - -rot ( intercept num den ) ;
+ : do-point ( x y -- ) skipping? ?dup if 1- to skipping? 2drop exit then + starting? if + 2dup in-start? if false to starting? else 2drop exit then + then + 2dup in-stop? if 0 to remaining 2drop exit then 2dup add-pt dot ;
@@ -1105,8 +1142,9 @@ ;
0 value nl-max 0 value nl-loc -d# 60 value nl-span -d# 30 value nl-stride +d# 160 value nl-span +d# 10 value nl-stride +d# 40 value nl-threshold : max-nonlinearity ( intercept num den -- nl ) 0 to nl-max ( intercept num den ) 0 to nl-loc @@ -1142,30 +1180,51 @@ magenta color-nl d# 500 ms loop ; +: at-5pm d# 30 d# 27 at-xy ." "(1b)[K" ; +: .tsmsg-drag + at-5pm ." Drag between targets." cr +; +: .tsmsg-few + at-5pm ." Too few points. Draw the line slowly. " cr +;
\ TODO: \ 1) Message and retry if slope and intercept not approximately correct \ slope can be checked with \ ( num den ) h# 10000 -rot */ LOW HIGH within \ ( expected slope is negative , so LOW and HIGH are negative ) -\ 2) Establish threshold for nonlinearity and fail if exceeded \ 3) Perhaps integrate the nonlinearity test with the targets test?
+: ((test-nonlinearity)) + ['] .tsmsg-drag to .tsmsg + begin ev( + draw-targets + 0 to #pts + #skip to skipping? + true to starting? + ['] do-point ev + #pts d# 400 < while + .tsmsg-few ['] .tsmsg-few to .tsmsg + d# 1000 ms + repeat +; + +: (test-nonlinearity) ( -- nonlinearity ) + ((test-nonlinearity)) + linear-least-squares ( intercept num den ) + 3dup red draw-line ( intercept num den ) + max-nonlinearity ( nonlinearity ) + at-5pm dup ." Nonlinearity: " .d cr ( nonlinearity ) + show-nonlinearity ( nonlinearity ) +; + : test-nonlinearity + d# 86400.000 to test-timeout alloc-bufs - begin ev( - 0 to #pts - 0 d# 27 at-xy ." Follow the line. Type a key to exit " cr - screen-h 6 - screen-h negate screen-w blue draw-line - ['] do-point ev - #pts d# 500 < while - 0 d# 27 at-xy ." Too few points. Draw the line slowly" cr - d# 2000 ms - repeat - linear-least-squares ( intercept num den ) - 3dup red draw-line ( intercept num den ) - ." Nonlinearity: " max-nonlinearity .d cr - show-nonlinearity + begin + (test-nonlinearity) + nl-threshold <= + until )ev free-bufs ; @@ -1334,7 +1393,6 @@
: mb-final ( -- error? ) open 0= if true exit then - d# 86400.000 to test-timeout ['] test-nonlinearity catch ?dup if .error fault then close faults @@ -1348,7 +1406,7 @@ test-station case h# 1 of mb-smt exit endof h# 2 of mb-assy exit endof - h# 4 of mb-final exit endof + h# 4 of mb-smt exit endof h# 11 of ir-pcb-smt exit endof h# 12 of ir-pcb-assy exit endof h# 13 of lg-tooling exit endof
