Author: wmb Date: Sat Jan 8 11:11:59 2011 New Revision: 2103 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2103
Log: OLPC XO-1.75 - Moved the codec-specific words from the sound driver into separate files for each of the two codec choices.
Added: cpu/arm/olpc/1.75/alc5624.fth cpu/arm/olpc/1.75/alc5631.fth Modified: cpu/arm/olpc/1.75/sound.fth
Added: cpu/arm/olpc/1.75/alc5624.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/olpc/1.75/alc5624.fth Sat Jan 8 11:11:59 2011 (r2103) @@ -0,0 +1,194 @@ +\ See license at end of file +purpose: Driver for Realtek ALC5624 audio CODEC chip + +: codec-bias-off ( -- ) + h# 8080 h# 02 codec-set + h# 8080 h# 04 codec-set + h# 0000 h# 3a codec! + h# 0000 h# 3c codec! + h# 0000 h# 3e codec! +; +: linux-codec-on + h# 0000 h# 26 codec! \ Don't power down any groups + h# 8000 h# 5e codec! \ Disable fast vref + h# 0c00 h# 3e codec! \ enable HP out volume power + h# 0002 h# 3a codec! \ enable Main bias + h# 2000 h# 3c codec! \ enable Vref + h# 6808 h# 0c codec! \ Stereo DAC Volume + h# 3f3f h# 14 codec! \ ADC Record Mixer Control + h# 4b40 h# 1c codec! \ Output Mixer Control + h# 0500 h# 22 codec! \ Microphone Control + h# 04e8 h# 40 codec! \ General Purpose Control +; +: codec-on ( -- ) + h# 0000 h# 26 codec! \ Don't power down any groups + h# 8002 h# 34 codec! \ Slave mode, 16 bits, left justified + b# 1000.1000.0011.1111 h# 3a codec! \ All on except MONO depop, 0-cross + b# 1010.0011.1111.0011 h# 3c codec! \ All on except ClassAB, PLL, speaker mixer, MONO mixer + b# 0011.1111.1100.1111 h# 3e codec! \ All on except MONO_OUT and PHONE in + h# 0140 h# 40 codec! \ MCLK is SYSCLK, HPamp Vmid 1.25, ClassDamp Vmid 1.5 +; +: codec-off ( -- ) + h# ef00 h# 26 codec! \ Power down everything +; +\ Mic bias 2 is for external mic +: mic-gain ( bits11:8 -- ) h# f00 h# 22 codec-field ; +: mic+0db ( -- ) 0 mic-gain ; \ Needed +: mic+20db ( -- ) h# 500 mic-gain ; \ Needed +: mic+30db ( -- ) h# a00 mic-gain ; +: mic+40db ( -- ) h# f00 mic-gain ; + +: mic-bias-off ( -- ) h# 000c h# 3a codec-clr ; +: mic-bias-on ( -- ) h# 000c h# 3a codec-set ; + +: mic1-high-bias ( -- ) h# 20 h# 22 codec-clr mic-bias-on ; \ 0.90*AVDD, e.g. 3V with AVDD=3.3V +: mic1-low-bias ( -- ) h# 20 h# 22 codec-set mic-bias-on ; \ 0.75*AVDD, e.g. 2.5V with AVDD=3.3V +: mic2-high-bias ( -- ) h# 10 h# 22 codec-clr mic-bias-on ; \ 0.90*AVDD, e.g. 3V with AVDD=3.3V +: mic2-low-bias ( -- ) h# 21 h# 22 codec-set mic-bias-on ; \ 0.75*AVDD, e.g. 2.5V with AVDD=3.3V + +\ The mic bias short circuit detection threshold can be set with reg 0x22 bits 1:0 - +\ 00:600uA 01:1200uA 1x:1800uA +\ 600uA is probably good for OLPC, since the 5.6K bias resistor limits the SC current to less than that. + +\ Sets both speakers simultaneously +: speakers-source ( value -- ) h# d800 h# 1c codec-field ; + +: speakers-off ( -- ) 0 speakers-source ; +: hp-mixer>speakers ( -- ) h# 4800 speakers-source ; +: speaker-mixer>speakers ( -- ) h# 9000 speakers-source ; +: mono>speakers ( -- ) h# d800 speakers-source ; + +: class-ab-speakers ( -- ) h# 2000 h# 1c codec-clr ; +: class-d-speakers ( -- ) h# 2000 h# 1c codec-set ; + +: headphones-off ( -- ) h# 300 h# 1c codec-clr ; +: headphones-on ( -- ) h# 300 h# 1c codec-set ; + +0 [if] \ OLPC does not connect the MONO output +: mono-source ( value -- ) h# c0 h# 1c codec-field ; +: mono-off ( -- ) 0 mono-source ; +: hp-mixer>mono ( -- ) h# 40 mono-source ; +: speaker-mixer>mono ( -- ) h# 80 mono-source ; +: mono-mixer>mono ( -- ) h# c0 mono-source ; +[then] + +: headphones-inserted? ( -- flag ) h# 54 codec@ 2 and 0<> ; + +\ The range is from -34.5 db to +12 dB +: gain>lr ( db -- true | regval false ) + 2* 3 / ( steps ) \ Converts -34.5 .. 12 db to -23 .. 8 steps + dup d# -23 < if ( steps ) + drop true + else ( steps ) + 8 swap - ( -steps ) + 0 max ( clipped-steps ) + dup 8 lshift or ( regval ) + false + then +; +\ The range is from -46.5 db to 0 dB +: >output-volume ( db -- regval mask ) + d# 12 + \ Bias to the range used by gain>lr + gain>lr if h# 8080 then h# 9f9f +; +: set-speaker-volume ( n -- ) >output-volume 2 codec-field ; +: set-headphone-volume ( n -- ) >output-volume 4 codec-field ; +\ : set-mono-volume ( n -- ) >output-volume 6 codec-field ; +: set-volume ( n -- ) + dup set-speaker-volume set-headphone-volume +; +d# 0 constant default-adc-gain \ 0 dB - range is -16.5 to +30 +d# 0 constant default-dac-gain \ 0 dB - range is -34.5 to +12 +d# 44 constant default-mic-gain \ 44 dB - range is -34.5 to +d# 0 constant default-speaker-volume \ 0 dB - range is -46.5 to 0 +d# 0 constant default-headphone-volume \ 0 dB - range is -46.5 to 0 + +: select-headphones ( -- ) h# 300 h# 1c codec! ; +: select-speakers-ab ( -- ) h# 4800 h# 1c codec! ; \ ClassAB, headphone mixer +: select-speakers ( -- ) h# 6800 h# 1c codec! ; \ ClassD, headphone mixer + +: set-line-in-gain ( n -- ) + gain>lr if h# e000 then h# ff1f h# 0a codec-field +; +: set-dac-gain ( n -- ) + gain>lr if h# e000 then h# ff1f h# 0c codec-field +; +false value external-mic? +: mic-routing ( -- n ) + \ Mute selected MIC inputs to the ADC as follows: + \ For external, we send MIC1 to left and MIC2 to right + \ For internal, we send MIC1 to both left and right + external-mic? if h# 2040 else h# 2020 then +; +: set-mic-boost ( db -- db' ) + dup d# 26 > if mic+40db d# 40 - exit then + dup d# 16 > if mic+30db d# 30 - exit then + dup d# 06 > if mic+20db d# 20 - exit then + mic+0db +; +: set-mic-gain ( db -- ) + set-mic-boost ( db' ) + gain>lr if ( ) \ Mute + \ Turn everything off + mic-bias-off ( ) + 0 h# 6060 h# e0e0 ( gain adc-mute mic-output-mute ) + else ( gain ) + mic-bias-on ( gain ) + \ Mic routing to ADC depends on internal or external mic + mic-routing ( gain adc-mute ) + \ To avoid feedback, we do not feedthrough the mic + h# e0e0 ( gain adc-mute mic-output-mute ) + then ( gain adc-mute mic-output-mute ) + h# e0e0 h# 10 codec-field ( gain adc-mute ) + h# 6060 h# 14 codec-field ( gain ) + h# 1f1f h# 0e codec-field +; +: set-adc-gain ( db -- ) \ Range is -16.5 dB to +30 dB + d# 18 - ( db' ) + gain>lr if 0 then ( gain ) + h# f9f h# 12 codec-field + h# 60 h# 12 codec-set \ Enable ADC zero-cross detectors +; +: set-default-gains ( -- ) + headphones-inserted? if select-headphones else select-speakers then + default-speaker-volume set-speaker-volume + default-headphone-volume set-headphone-volume + default-dac-gain set-dac-gain + default-mic-gain set-mic-gain + default-adc-gain set-adc-gain +; + +: set-codec-sample-rate ( rate -- ) + case + d# 8000 of h# 2222 h# 5272 endof + d# 16000 of h# 2020 h# 2272 endof + d# 32000 of h# 2121 h# 2172 endof + d# 48000 of h# 0000 h# 3072 endof + ( default ) true abort" Unsupported audio sample rate" + endcase ( reg62val2 reg60val ) + h# 60 codec! h# 62 codec! +; + +\ LICENSE_BEGIN +\ Copyright (c) 2011 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Added: cpu/arm/olpc/1.75/alc5631.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/olpc/1.75/alc5631.fth Sat Jan 8 11:11:59 2011 (r2103) @@ -0,0 +1,200 @@ +\ See license at end of file +purpose: Driver for Realtek ALC5631Q audio CODEC chip + +: codec-on ( -- ) + h# 8001 h# 34 codec! \ Slave mode, 16 bits, left justified + b# 1001.1111.1110.0000 h# 3a codec! \ All on + b# 1111.1100.0011.1100 h# 3b codec! \ All on except PLL + b# 1010.0000.0001.1101 h# 3c codec! \ All on except AX and MONO + b# 1111.1100.0000.0000 h# 3e codec! \ AXI and MONO IN off +\ h# 8c00 h# 40 codec! \ Speaker Amp Auto Ratio GAIN, use HPFs + h# 8000 h# 40 codec! \ Speaker Amp Auto Ratio GAIN, no HPFs + h# 0000 h# 42 codec! \ Use MCLK, not PLL + b# 1110.1100.1001.0000 h# 52 codec! \ Protection on + h# 4000 h# 56 codec! \ Power on Cap-free block with de-pop +; +: codec-off ( -- ) + 0 h# 3a codec! \ All off + 0 h# 3b codec! \ All off + 0 h# 3c codec! \ All off + 0 h# 3e codec! \ All off +; +: mic-bias-off ( -- ) h# 000c h# 3b codec-clr ; +: mic-bias-on ( -- ) h# 000c h# 3b codec-set ; + +: mic1-high-bias ( -- ) h# 80 h# 22 codec-clr mic-bias-on ; \ 0.90*AVDD, e.g. 3V with AVDD=3.3V +: mic1-low-bias ( -- ) h# 80 h# 22 codec-set mic-bias-on ; \ 0.75*AVDD, e.g. 2.5V with AVDD=3.3V +: mic2-high-bias ( -- ) h# 08 h# 22 codec-clr mic-bias-on ; \ 0.90*AVDD, e.g. 3V with AVDD=3.3V +: mic2-low-bias ( -- ) h# 08 h# 22 codec-set mic-bias-on ; \ 0.75*AVDD, e.g. 2.5V with AVDD=3.3V + +\ The range is from -46.5 db to +12 dB +: gain>lr-12 ( db -- true | regval false ) + d# 12 min ( db' ) + 2* 3 / ( steps ) \ Converts -46.5 .. 12 db to -31 .. 8 steps + dup d# -31 < if ( steps ) + drop true + else ( steps ) + 8 swap - ( -steps ) + 0 max ( clipped-steps ) + dup 8 lshift or ( regval ) + false + then +; +\ The range is from -46.5 db to 0 dB +: gain>lr ( db -- true | regval false ) + 0 min ( db' ) + 2* 3 / ( steps ) \ Converts -46.5 .. 12 db to -31 .. 8 steps + dup d# -31 < if ( steps ) + drop true + else ( steps ) + 0 swap - ( -steps ) + 0 max ( clipped-steps ) + dup 8 lshift or ( regval ) + false + then +; + +\ This sets up a simple routing from the DAC to the headphone and speaker outputs +: output-config ( -- ) + h# df00 h# 1a codec! \ DACL -> OUTMIXL + h# df00 h# 1c codec! \ DACR -> OUTMIXR + h# 4040 h# 04 codec-set \ OUTMIXLR -> HPOVOLLR + h# d0d0 h# 28 codec! \ DACLR -> SPKMIXLR + h# 4040 h# 02 codec-set \ SPKMIXLR -> SPKVOLLR + h# 9000 h# 2a codec! \ SPKVOLL -> SPOLMIX, SPKVOLR -> SPORMIX + h# 0000 h# 2c codec! \ SPOxMIX -> SPKRMUX, HPOVOL -> HPMUX +; + +: mute-speakers ( -- ) h# 8080 2 codec-set ; +: set-speaker-volume ( n -- ) \ DONE + gain>lr-12 if h# 8080 then h# bfbf 2 codec-field +; +: mute-headphones ( -- ) h# 8080 4 codec-set ; +: set-headphone-volume ( n -- ) \ DONE + gain>lr if h# 8080 then h# 9f9f 4 codec-field +; +: set-volume ( n -- ) + headphones-inserted? if + set-headphone-volume + else + set-speaker-volume + then +; +d# 0 constant default-adc-gain \ 0 dB - range is -96.625 to +28.5 +d# 0 constant default-dac-gain \ 0 dB - range is -96.625 to +28.5 +d# 44 constant default-mic-gain \ 44 dB - range is 0 to 50 dB +d# 0 constant default-speaker-volume \ 0 dB - range is -46.5 to +12 +d# -10 constant default-headphone-volume \ -10 dB - range is -46.5 to 0 + +: adc-mute-all ( -- ) h# f0f0 h# 14 codec! ; +: adc-mute-mic ( -- ) h# 4040 h# 14 codec-set ; +: adc-unmute-mic ( -- ) h# 4040 h# 14 codec-clr ; +\ : adc-unmute-outmix ( -- ) h# 8080 h# 14 codec-clr ; + +\ The useful one is outmix-unmute-dac +: outmix-mute-all ( -- ) h# ff00 dup h# 1a codec! h# 1c codec! ; +: outmix-mute-mic ( -- ) h# 1000 dup h# 1a codec-set h# 1c codec-set ; +: outmix-unmute-mic ( -- ) h# 1000 dup h# 1a codec-clr h# 1c codec-clr ; +: outmix-mute-dac ( -- ) h# 2000 dup h# 1a codec-set h# 1c codec-set ; +: outmix-unmute-dac ( -- ) h# 2000 dup h# 1a codec-clr h# 1c codec-clr ; +: outmix-mute-recmix ( -- ) h# 8000 dup h# 1a codec-set h# 1c codec-set ; +: outmix-unmute-recmix ( -- ) h# 8000 dup h# 1a codec-clr h# 1c codec-clr ; + +: gain>lr-3/8 ( -- lrgain boost ) + d# 28 min + dup 0>= if ( n ) + 8 3 */ ( boost ) \ Convert to .375 dB increments + 0 swap ( lrgain boost ) + else ( n ) + dup d# -96 <= if ( n ) + drop ( ) + h# ffff h# 8080 ( lrgain boost ) + else ( n ) + negate 8 3 */ ( steps ) + dup bwjoin ( lrgain ) + 0 ( lrgain boost ) + then ( lrgain boost ) + then ( lrgain boost ) +; +: set-dac-gain ( n -- ) + dup d# -96 < if outmix-mute-dac else outmix-unmute-dac then + gain>lr-3/8 h# 0c codec! h# 10 codec! +; +: set-adc-gain ( n -- ) + gain>lr-3/8 h# 12 codec! h# 16 codec! +; +: mic1-balanced ( -- ) h# 8000 h# 8000 h# 0e codec-field ; +: mic1-single-ended ( -- ) 0 h# 8000 h# 0e codec-field ; +: mic2-balanced ( -- ) h# 0080 h# 0080 h# 0e codec-field ; +: mic2-single-ended ( -- ) 0 h# 0080 h# 0e codec-field ; + +false value external-mic? +: mic-routing ( -- n ) + mic1-single-ended mic2-single-ended + adc-unmute-mic +; +: db>mic-boost ( db -- code ) + dup d# 52 >= if drop h# 8800 exit then + dup d# 50 >= if drop h# 7700 exit then + dup d# 44 >= if drop h# 6600 exit then + dup d# 40 >= if drop h# 5500 exit then + dup d# 35 >= if drop h# 4400 exit then + dup d# 30 >= if drop h# 3300 exit then + dup d# 24 >= if drop h# 2200 exit then + dup d# 20 >= if drop h# 1100 exit then + drop h# 0000 +; +: set-mic-gain ( db -- ) + db>mic-boost h# ff00 h# 22 codec-field + mic-routing +; +: mic+0db ( -- ) 0 set-mic-gain ; +: mic+20db ( -- ) d# 20 set-mic-gain ; +: set-default-gains ( -- ) + output-config + headphones-inserted? if + default-headphone-volume set-headphone-volume + mute-speakers + else + default-speaker-volume set-speaker-volume + mute-headphones + then + default-dac-gain set-dac-gain + default-mic-gain set-mic-gain + default-adc-gain set-adc-gain +; + +: set-codec-sample-rate ( rate -- ) + case + d# 8000 of h# 2222 h# 5272 endof + d# 16000 of h# 2020 h# 2272 endof + d# 32000 of h# 2121 h# 2172 endof + d# 48000 of h# 0000 h# 3072 endof + ( default ) true abort" Unsupported audio sample rate" + endcase ( reg62val2 reg60val ) + h# 60 codec! h# 62 codec! +; + +\ LICENSE_BEGIN +\ Copyright (c) 2011 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Modified: cpu/arm/olpc/1.75/sound.fth ============================================================================== --- cpu/arm/olpc/1.75/sound.fth Sat Jan 8 10:49:39 2011 (r2102) +++ cpu/arm/olpc/1.75/sound.fth Sat Jan 8 11:11:59 2011 (r2103) @@ -187,62 +187,6 @@ r> codec! ( ) ;
-: codec-bias-off ( -- ) -[ifdef] cl2-a1 - h# 8080 h# 02 codec-set -[else] - h# c0c0 h# 02 codec-set -[then] - h# 8080 h# 04 codec-set - h# 0000 h# 3a codec! - h# 0000 h# 3c codec! - h# 0000 h# 3e codec! -; -: linux-codec-on - h# 0000 h# 26 codec! \ Don't power down any groups - h# 8000 h# 5e codec! \ Disable fast vref - h# 0c00 h# 3e codec! \ enable HP out volume power - h# 0002 h# 3a codec! \ enable Main bias - h# 2000 h# 3c codec! \ enable Vref - h# 6808 h# 0c codec! \ Stereo DAC Volume - h# 3f3f h# 14 codec! \ ADC Record Mixer Control - h# 4b40 h# 1c codec! \ Output Mixer Control - h# 0500 h# 22 codec! \ Microphone Control - h# 04e8 h# 40 codec! \ General Purpose Control -; -: codec-on ( -- ) -[ifdef] cl2-a1 - h# 30 1 set-twsi-target - h# 0000 h# 26 codec! \ Don't power down any groups - h# 8002 h# 34 codec! \ Slave mode, 16 bits, left justified - b# 1000.1000.0011.1111 h# 3a codec! \ All on except MONO depop, 0-cross - b# 1010.0011.1111.0011 h# 3c codec! \ All on except ClassAB, PLL, speaker mixer, MONO mixer - b# 0011.1111.1100.1111 h# 3e codec! \ All on except MONO_OUT and PHONE in - h# 0140 h# 40 codec! \ MCLK is SYSCLK, HPamp Vmid 1.25, ClassDamp Vmid 1.5 -[else] - h# 34 1 set-twsi-target - h# 8001 h# 34 codec! \ Slave mode, 16 bits, left justified - b# 1001.1111.1110.0000 h# 3a codec! \ All on - b# 1111.1100.0011.1100 h# 3b codec! \ All on except PLL - b# 1010.0000.0001.1101 h# 3c codec! \ All on except AX and MONO - b# 1111.1100.0000.0000 h# 3e codec! \ AXI and MONO IN off -\ h# 8c00 h# 40 codec! \ Speaker Amp Auto Ratio GAIN, use HPFs - h# 8000 h# 40 codec! \ Speaker Amp Auto Ratio GAIN, no HPFs - h# 0000 h# 42 codec! \ Use MCLK, not PLL - b# 1110.1100.1001.0000 h# 52 codec! \ Protection on - h# 4000 h# 56 codec! \ Power on Cap-free block with de-pop -[then] -; -: codec-off ( -- ) -[ifdef] cl2-a1 - h# ef00 h# 26 codec! \ Power down everything -[else] - 0 h# 3a codec! \ All off - 0 h# 3b codec! \ All off - 0 h# 3c codec! \ All off - 0 h# 3e codec! \ All off -[then] -; d# 48000 value sample-rate
\ Longest time to wait for a buffer event - a little more @@ -250,20 +194,18 @@ \ at the current sample rate. 0 value buf-timeout
-: set-sample-rate ( rate -- ) - to sample-rate - sample-rate case - d# 8000 of h# 2222 h# 5272 d# 48 d# 129 endof - d# 16000 of h# 2020 h# 2272 d# 24 d# 65 endof - d# 32000 of h# 2121 h# 2172 d# 12 d# 33 endof - d# 48000 of h# 0000 h# 3072 d# 8 d# 23 endof +: set-ctlr-sample-rate ( rate -- ) + case + d# 8000 of d# 48 d# 129 endof + d# 16000 of d# 24 d# 65 endof + d# 32000 of d# 12 d# 33 endof + d# 48000 of d# 8 d# 23 endof ( default ) true abort" Unsupported audio sample rate" - endcase ( reg62val2 reg60val sspareg34val timeout ) + endcase ( sspareg34val timeout ) to buf-timeout - 9 lshift h# 183 or h# 34 sspa! h# 60 codec! h# 62 codec! + 9 lshift h# 183 or h# 34 sspa! ;
-\ Mic bias 2 is for external mic \ I think we don't need to use the audio PLL, because we are using the PMUM M/N divider \ DIV_MCL 0 DIV_FBCLK 01 FRACT 00da1 \ POSTDIV 1 DIV_OCLK_MODULO 000 (NA) DIV_OCLK_PATTERN 00 (NA) @@ -404,262 +346,24 @@ [then]
[ifdef] cl2-a1 -\ Realtek ALC5624 CODEC -: mic-gain ( bits11:8 -- ) h# f00 h# 22 codec-field ; -: mic+0db ( -- ) 0 mic-gain ; \ Needed -: mic+20db ( -- ) h# 500 mic-gain ; \ Needed -: mic+30db ( -- ) h# a00 mic-gain ; -: mic+40db ( -- ) h# f00 mic-gain ; - -: mic-bias-off ( -- ) h# 000c h# 3a codec-clr ; -: mic-bias-on ( -- ) h# 000c h# 3a codec-set ; - -: mic1-high-bias ( -- ) h# 20 h# 22 codec-clr mic-bias-on ; \ 0.90*AVDD, e.g. 3V with AVDD=3.3V -: mic1-low-bias ( -- ) h# 20 h# 22 codec-set mic-bias-on ; \ 0.75*AVDD, e.g. 2.5V with AVDD=3.3V -: mic2-high-bias ( -- ) h# 10 h# 22 codec-clr mic-bias-on ; \ 0.90*AVDD, e.g. 3V with AVDD=3.3V -: mic2-low-bias ( -- ) h# 21 h# 22 codec-set mic-bias-on ; \ 0.75*AVDD, e.g. 2.5V with AVDD=3.3V - -\ The mic bias short circuit detection threshold can be set with reg 0x22 bits 1:0 - -\ 00:600uA 01:1200uA 1x:1800uA -\ 600uA is probably good for OLPC, since the 5.6K bias resistor limits the SC current to less than that. - -\ Sets both speakers simultaneously -: speakers-source ( value -- ) h# d800 h# 1c codec-field ; - -: speakers-off ( -- ) 0 speakers-source ; -: hp-mixer>speakers ( -- ) h# 4800 speakers-source ; -: speaker-mixer>speakers ( -- ) h# 9000 speakers-source ; -: mono>speakers ( -- ) h# d800 speakers-source ; - -: class-ab-speakers ( -- ) h# 2000 h# 1c codec-clr ; -: class-d-speakers ( -- ) h# 2000 h# 1c codec-set ; - -: headphones-off ( -- ) h# 300 h# 1c codec-clr ; -: headphones-on ( -- ) h# 300 h# 1c codec-set ; - -0 [if] \ OLPC does not connect the MONO output -: mono-source ( value -- ) h# c0 h# 1c codec-field ; -: mono-off ( -- ) 0 mono-source ; -: hp-mixer>mono ( -- ) h# 40 mono-source ; -: speaker-mixer>mono ( -- ) h# 80 mono-source ; -: mono-mixer>mono ( -- ) h# c0 mono-source ; -[then] +: init-smbus ( -- ) h# 30 1 set-twsi-target ;
-: headphones-inserted? ( -- flag ) h# 54 codec@ 2 and 0<> ; - -\ The range is from -34.5 db to +12 dB -: gain>lr ( db -- true | regval false ) - 2* 3 / ( steps ) \ Converts -34.5 .. 12 db to -23 .. 8 steps - dup d# -23 < if ( steps ) - drop true - else ( steps ) - 8 swap - ( -steps ) - 0 max ( clipped-steps ) - dup 8 lshift or ( regval ) - false - then -; -\ The range is from -46.5 db to 0 dB -: >output-volume ( db -- regval mask ) - d# 12 + \ Bias to the range used by gain>lr - gain>lr if h# 8080 then h# 9f9f -; -: set-speaker-volume ( n -- ) >output-volume 2 codec-field ; -: set-headphone-volume ( n -- ) >output-volume 4 codec-field ; -\ : set-mono-volume ( n -- ) >output-volume 6 codec-field ; -: set-volume ( n -- ) - dup set-speaker-volume set-headphone-volume -; -d# 0 constant default-adc-gain \ 0 dB - range is -16.5 to +30 -d# 0 constant default-dac-gain \ 0 dB - range is -34.5 to +12 -d# 44 constant default-mic-gain \ 44 dB - range is -34.5 to -d# 0 constant default-speaker-volume \ 0 dB - range is -46.5 to 0 -d# 0 constant default-headphone-volume \ 0 dB - range is -46.5 to 0 - -: select-headphones ( -- ) h# 300 h# 1c codec! ; -: select-speakers-ab ( -- ) h# 4800 h# 1c codec! ; \ ClassAB, headphone mixer -: select-speakers ( -- ) h# 6800 h# 1c codec! ; \ ClassD, headphone mixer - -: set-line-in-gain ( n -- ) - gain>lr if h# e000 then h# ff1f h# 0a codec-field -; -: set-dac-gain ( n -- ) - gain>lr if h# e000 then h# ff1f h# 0c codec-field -; -false value external-mic? -: mic-routing ( -- n ) - \ Mute selected MIC inputs to the ADC as follows: - \ For external, we send MIC1 to left and MIC2 to right - \ For internal, we send MIC1 to both left and right - external-mic? if h# 2040 else h# 2020 then -; -: set-mic-boost ( db -- db' ) - dup d# 26 > if mic+40db d# 40 - exit then - dup d# 16 > if mic+30db d# 30 - exit then - dup d# 06 > if mic+20db d# 20 - exit then - mic+0db -; -: set-mic-gain ( db -- ) - set-mic-boost ( db' ) - gain>lr if ( ) \ Mute - \ Turn everything off - mic-bias-off ( ) - 0 h# 6060 h# e0e0 ( gain adc-mute mic-output-mute ) - else ( gain ) - mic-bias-on ( gain ) - \ Mic routing to ADC depends on internal or external mic - mic-routing ( gain adc-mute ) - \ To avoid feedback, we do not feedthrough the mic - h# e0e0 ( gain adc-mute mic-output-mute ) - then ( gain adc-mute mic-output-mute ) - h# e0e0 h# 10 codec-field ( gain adc-mute ) - h# 6060 h# 14 codec-field ( gain ) - h# 1f1f h# 0e codec-field -; -: set-adc-gain ( db -- ) \ Range is -16.5 dB to +30 dB - d# 18 - ( db' ) - gain>lr if 0 then ( gain ) - h# f9f h# 12 codec-field - h# 60 h# 12 codec-set \ Enable ADC zero-cross detectors -; +fload ${BP}/cpu/arm/olpc/1.75/alc5624.fth \ Realtek ALC5624 CODEC [else] -\ Realtek ALC5631Q CODEC -: mic-bias-off ( -- ) h# 000c h# 3b codec-clr ; -: mic-bias-on ( -- ) h# 000c h# 3b codec-set ; - -: mic1-high-bias ( -- ) h# 80 h# 22 codec-clr mic-bias-on ; \ 0.90*AVDD, e.g. 3V with AVDD=3.3V -: mic1-low-bias ( -- ) h# 80 h# 22 codec-set mic-bias-on ; \ 0.75*AVDD, e.g. 2.5V with AVDD=3.3V -: mic2-high-bias ( -- ) h# 08 h# 22 codec-clr mic-bias-on ; \ 0.90*AVDD, e.g. 3V with AVDD=3.3V -: mic2-low-bias ( -- ) h# 08 h# 22 codec-set mic-bias-on ; \ 0.75*AVDD, e.g. 2.5V with AVDD=3.3V +: init-smbus ( -- ) h# 34 1 set-twsi-target ;
: headphones-inserted? ( -- flag ) d# 97 gpio-pin@ ; : microphone-inserted? ( -- flag ) d# 96 gpio-pin@ ;
-\ The range is from -46.5 db to +12 dB -: gain>lr-12 ( db -- true | regval false ) - d# 12 min ( db' ) - 2* 3 / ( steps ) \ Converts -46.5 .. 12 db to -31 .. 8 steps - dup d# -31 < if ( steps ) - drop true - else ( steps ) - 8 swap - ( -steps ) - 0 max ( clipped-steps ) - dup 8 lshift or ( regval ) - false - then -; -\ The range is from -46.5 db to 0 dB -: gain>lr ( db -- true | regval false ) - 0 min ( db' ) - 2* 3 / ( steps ) \ Converts -46.5 .. 12 db to -31 .. 8 steps - dup d# -31 < if ( steps ) - drop true - else ( steps ) - 0 swap - ( -steps ) - 0 max ( clipped-steps ) - dup 8 lshift or ( regval ) - false - then -; - -\ This sets up a simple routing from the DAC to the headphone and speaker outputs -: output-config ( -- ) - h# df00 h# 1a codec! \ DACL -> OUTMIXL - h# df00 h# 1c codec! \ DACR -> OUTMIXR - h# 4040 h# 04 codec-set \ OUTMIXLR -> HPOVOLLR - h# d0d0 h# 28 codec! \ DACLR -> SPKMIXLR - h# 4040 h# 02 codec-set \ SPKMIXLR -> SPKVOLLR - h# 9000 h# 2a codec! \ SPKVOLL -> SPOLMIX, SPKVOLR -> SPORMIX - h# 0000 h# 2c codec! \ SPOxMIX -> SPKRMUX, HPOVOL -> HPMUX -; - -: mute-speakers ( -- ) h# 8080 2 codec-set ; -: set-speaker-volume ( n -- ) \ DONE - gain>lr-12 if h# 8080 then h# bfbf 2 codec-field -; -: mute-headphones ( -- ) h# 8080 4 codec-set ; -: set-headphone-volume ( n -- ) \ DONE - gain>lr if h# 8080 then h# 9f9f 4 codec-field -; -: set-volume ( n -- ) - headphones-inserted? if - set-headphone-volume - else - set-speaker-volume - then -; -d# 0 constant default-adc-gain \ 0 dB - range is -96.625 to +28.5 -d# 0 constant default-dac-gain \ 0 dB - range is -96.625 to +28.5 -d# 44 constant default-mic-gain \ 44 dB - range is 0 to 50 dB -d# 0 constant default-speaker-volume \ 0 dB - range is -46.5 to +12 -d# -10 constant default-headphone-volume \ -10 dB - range is -46.5 to 0 - -: adc-mute-all ( -- ) h# f0f0 h# 14 codec! ; -: adc-mute-mic ( -- ) h# 4040 h# 14 codec-set ; -: adc-unmute-mic ( -- ) h# 4040 h# 14 codec-clr ; -\ : adc-unmute-outmix ( -- ) h# 8080 h# 14 codec-clr ; - -\ The useful one is outmix-unmute-dac -: outmix-mute-all ( -- ) h# ff00 dup h# 1a codec! h# 1c codec! ; -: outmix-mute-mic ( -- ) h# 1000 dup h# 1a codec-set h# 1c codec-set ; -: outmix-unmute-mic ( -- ) h# 1000 dup h# 1a codec-clr h# 1c codec-clr ; -: outmix-mute-dac ( -- ) h# 2000 dup h# 1a codec-set h# 1c codec-set ; -: outmix-unmute-dac ( -- ) h# 2000 dup h# 1a codec-clr h# 1c codec-clr ; -: outmix-mute-recmix ( -- ) h# 8000 dup h# 1a codec-set h# 1c codec-set ; -: outmix-unmute-recmix ( -- ) h# 8000 dup h# 1a codec-clr h# 1c codec-clr ; - -: gain>lr-3/8 ( -- lrgain boost ) - d# 28 min - dup 0>= if ( n ) - 8 3 */ ( boost ) \ Convert to .375 dB increments - 0 swap ( lrgain boost ) - else ( n ) - dup d# -96 <= if ( n ) - drop ( ) - h# ffff h# 8080 ( lrgain boost ) - else ( n ) - negate 8 3 */ ( steps ) - dup bwjoin ( lrgain ) - 0 ( lrgain boost ) - then ( lrgain boost ) - then ( lrgain boost ) -; -: set-dac-gain ( n -- ) - dup d# -96 < if outmix-mute-dac else outmix-unmute-dac then - gain>lr-3/8 h# 0c codec! h# 10 codec! -; -: set-adc-gain ( n -- ) - gain>lr-3/8 h# 12 codec! h# 16 codec! -; -: mic1-balanced ( -- ) h# 8000 h# 8000 h# 0e codec-field ; -: mic1-single-ended ( -- ) 0 h# 8000 h# 0e codec-field ; -: mic2-balanced ( -- ) h# 0080 h# 0080 h# 0e codec-field ; -: mic2-single-ended ( -- ) 0 h# 0080 h# 0e codec-field ; - -false value external-mic? -: mic-routing ( -- n ) - mic1-single-ended mic2-single-ended - adc-unmute-mic -; -: db>mic-boost ( db -- code ) - dup d# 52 >= if drop h# 8800 exit then - dup d# 50 >= if drop h# 7700 exit then - dup d# 44 >= if drop h# 6600 exit then - dup d# 40 >= if drop h# 5500 exit then - dup d# 35 >= if drop h# 4400 exit then - dup d# 30 >= if drop h# 3300 exit then - dup d# 24 >= if drop h# 2200 exit then - dup d# 20 >= if drop h# 1100 exit then - drop h# 0000 -; -: set-mic-gain ( db -- ) - db>mic-boost h# ff00 h# 22 codec-field - mic-routing -; -: mic+0db ( -- ) 0 set-mic-gain ; -: mic+20db ( -- ) d# 20 set-mic-gain ; +fload ${BP}/cpu/arm/olpc/1.75/alc5631.fth \ Realtek ALC5631Q CODEC [then]
+: set-sample-rate ( rate -- ) + dup to sample-rate + dup set-ctlr-sample-rate + set-codec-sample-rate +; + \ This is called from "record" in "mic-test" in "selftest" : set-record-gain ( db -- ) \ translate value from ac97 selftest code into our default value @@ -674,24 +378,9 @@ : mono ;
: init-codec ( -- ) + init-smbus codec-on -[ifdef] cl2-a1 - headphones-inserted? if select-headphones else select-speakers then - default-speaker-volume set-speaker-volume - default-headphone-volume set-headphone-volume -[else] - output-config - headphones-inserted? if - default-headphone-volume set-headphone-volume - mute-speakers - else - default-speaker-volume set-speaker-volume - mute-headphones - then -[then] - default-dac-gain set-dac-gain - default-mic-gain set-mic-gain - default-adc-gain set-adc-gain + set-default-gains d# 48000 set-sample-rate ; 0 value open-count @@ -712,3 +401,27 @@ fload ${BP}/dev/geode/ac97/selftest.fth
end-package + +\ LICENSE_BEGIN +\ Copyright (c) 2011 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
