Author: quozl Date: Tue Apr 17 03:04:04 2012 New Revision: 2944 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2944
Log: OLPC XO-1.75 - restore thermal protection after suspend, #11779
Modified: cpu/arm/mmp2/dramrecal.fth cpu/arm/mmp2/thermal.fth
Modified: cpu/arm/mmp2/dramrecal.fth ============================================================================== --- cpu/arm/mmp2/dramrecal.fth Fri Apr 13 07:01:36 2012 (r2943) +++ cpu/arm/mmp2/dramrecal.fth Tue Apr 17 03:04:04 2012 (r2944) @@ -869,6 +869,7 @@ timers-wake resume-usb enable-interrupts + init-thermal-sensor ; : strp ( -- ) ec-rst-pwr str ec-max-pwr .d ." mW " soc .% space ;
Modified: cpu/arm/mmp2/thermal.fth ============================================================================== --- cpu/arm/mmp2/thermal.fth Fri Apr 13 07:01:36 2012 (r2943) +++ cpu/arm/mmp2/thermal.fth Tue Apr 17 03:04:04 2012 (r2944) @@ -1,11 +1,25 @@ \ See license at end of file purpose: Driver for the MMP2 thermal sensor
+\ See also cforth:src/app/arm-xo-1.75/thermal.fth h# 013200 value thermal-base +: room-temp@ ( -- n ) thermal-base io@ ; +: room-temp! ( n -- ) thermal-base io! ; +thermal-base h# 4 + value wd-thresh +: wd-thresh@ ( -- n ) wd-thresh io@ ; +: wd-thresh! ( n -- ) wd-thresh io! ; +\ thermal-base h# 8 + value lo-thresh +\ thermal-base h# c + value hi-thresh +thermal-base h# 10 + value ts-ctrl +: ts-ctrl! ( n -- ) ts-ctrl io! ; + : init-thermal-sensor ( -- ) thermal-base io@ h# 400 and if exit then 7 h# 90 apbc! 3 h# 90 apbc! \ Enable clocks to thermal sensor - h# 10000 thermal-base io! \ Enable sensing + h# 10000 room-temp! \ Enable sensing + d# 696 wd-thresh! \ Set thermal watchdog threshold to 85C + h# 88 ts-ctrl! \ Clear thermal watchdog reset status + \ Set thermal watchdog reset enable ;
\ thermal watchdog is enabled by CForth @@ -46,10 +60,6 @@ wdtpcr io! ;
-thermal-base h# 4 + value wd-thresh -: wd-thresh@ ( -- n ) wd-thresh io@ ; -: wd-thresh! ( n -- ) wd-thresh io! ; - : .c ( n -- ) (.) type ." C " ;
: .thermal
