Author: wmb Date: 2010-01-09 01:35:42 +0100 (Sat, 09 Jan 2010) New Revision: 1655
Modified: cpu/x86/pc/olpc/via/devices.fth Log: Avoid memory leakage from "probe-usb" by creating the int and ext devaliases only once.
Modified: cpu/x86/pc/olpc/via/devices.fth =================================================================== --- cpu/x86/pc/olpc/via/devices.fth 2010-01-09 00:20:44 UTC (rev 1654) +++ cpu/x86/pc/olpc/via/devices.fth 2010-01-09 00:35:42 UTC (rev 1655) @@ -338,6 +338,21 @@ devalias sd /sd/disk@2 devalias net /wlan
+stand-init: Standard aliases + atest? if + " int" " /ide@0/disk" $devalias + " ext" " /sd/disk@2" $devalias + else + board-revision h# d28 < if \ B2 and earlier + " int" " /sd/disk@1" $devalias + " ext" " /sd/disk@2" $devalias + else + " ext" " /sd/disk@1" $devalias + " int" " /sd/disk@3" $devalias + then + then +; + \ The "int" devalias is defined in report-disk at runtime, since it \ varies between A-test and later boards.
@@ -360,19 +375,6 @@ " disk" " /usb@10,2/disk" ?report-device \ USB 1.1 " disk" " /usb@10,1/disk" ?report-device \ USB 1.1 " disk" " /usb@10,0/disk" ?report-device \ USB 1.1 - - atest? if - " int" " /ide@0/disk" $devalias - " ext" " /sd/disk@2" $devalias - else - board-revision h# d28 < if \ B2 and earlier - " int" " /sd/disk@1" $devalias - " ext" " /sd/disk@2" $devalias - else - " ext" " /sd/disk@1" $devalias - " int" " /sd/disk@3" $devalias - then - then ;
: report-keyboard ( -- ) @@ -389,7 +391,15 @@ : report-net ( -- ) " /usb/ethernet" 2dup locate-device 0= if ( name$ phandle ) drop ( name$ ) - " net" 2swap $devalias ( ) + + \ Don't recreate the alias if it is already correct + " net" aliased? if ( name$ existing-name$ ) + 2over $= if ( name$ ) + 2drop exit ( -- ) + then ( name$ ) + then ( name$ ) + + " net" 2swap $devalias ( ) else ( name$ ) 2drop ( ) then
