Author: rsmith Date: Mon Apr 5 22:21:48 2010 New Revision: 1778 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/1778
Log: Revert charge-log
- This does not seem to have been tested enough. Its broken. Remove it for now to get the pre-release out and fix it later.
Modified: cpu/x86/pc/olpc/charge.fth
Modified: cpu/x86/pc/olpc/charge.fth ============================================================================== --- cpu/x86/pc/olpc/charge.fth Mon Apr 5 21:44:04 2010 (r1777) +++ cpu/x86/pc/olpc/charge.fth Mon Apr 5 22:21:48 2010 (r1778) @@ -39,20 +39,21 @@ h# 100 buffer: fname-buf
: charge-log-append ( adr len -- ) - fname-buf $append-open + fname-buf count $append-open ftype fcr ofd @ fclose ;
+[ifdef] notdef : charge-log ( "filename" -- ) \ filename is optional ['] safe-parse-word catch if - fname-buf place + " sd:\charge.log" fname-buf place else - " sd:\charge.log" fname-buf place + fname-buf place then ." Logging to: " fname-buf count type cr - fname-buf $new-file + fname-buf count $new-file ofd @ fclose
" chg_log Ver: 1.0" charge-log-append @@ -79,6 +80,7 @@ key? until key drop ; +[then]
: watch-charge ( -- ) \ 5 seconds is the default unless the user sets wake-delay
