Author: wmb Date: Wed Jan 19 08:05:12 2011 New Revision: 2119 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2119
Log: inflate.c - removed a small vestige of GPL code (a single #define) so the code is clean - based on stuff that Mark Adler's put in the public domain.
Modified: forth/wrapper/zip/inflate.c
Modified: forth/wrapper/zip/inflate.c ============================================================================== --- forth/wrapper/zip/inflate.c Tue Jan 18 22:41:32 2011 (r2118) +++ forth/wrapper/zip/inflate.c Wed Jan 19 08:05:12 2011 (r2119) @@ -70,12 +70,6 @@ [OK: Changes for Open Firmware by Mike Tuciarone, June 1994.] */
-/* gzip.h -- common declarations for all gzip modules - * Copyright (C) 1992-1993 Jean-loup Gailly. - * This is free software; you can redistribute it and/or modify it under the - * terms of the GNU General Public License, see the file COPYING. - */ - #define u_long unsigned long #define u_short unsigned short #define u_char unsigned char @@ -86,8 +80,7 @@ static int huft_fixed(); static int huft_dynamic();
-/* gzip flag byte */ -#define ORIG_NAME 0x08 /* bit 3 set: original file name present */ +#define FILENAME_PRESENT 0x08 /* flag byte bit meaning filename follows */
/* ROM * Workspace definitions @@ -207,7 +200,7 @@ flags = NEXTBYTE; for (n = 0; n < 6; ++n) (void) NEXTBYTE; - if (flags & ORIG_NAME) + if (flags & FILENAME_PRESENT) while (NEXTBYTE) ; }
