Author: quozl Date: Tue Oct 30 09:41:57 2012 New Revision: 3398 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3398
Log: spiflash - rework identification logic, verified against GD25Q16B W25Q16CVSSIG MX25L1635E MX25U1635E MX25E8035
Modified: dev/olpc/spiflash/spiflash.fth
Modified: dev/olpc/spiflash/spiflash.fth ============================================================================== --- dev/olpc/spiflash/spiflash.fth Tue Oct 30 07:37:03 2012 (r3397) +++ dev/olpc/spiflash/spiflash.fth Tue Oct 30 09:41:57 2012 (r3398) @@ -279,7 +279,7 @@ r> rot free-mem ( mismatch? ) ;
-: jedec-id ( -- b3b2b1) +: jedec-id ( -- b3b2b1 ) h# 9f spi-cmd spi-in spi-in spi-in spi-cs-off ( b1 b2 b3 ) 0 bljoin ; @@ -301,23 +301,41 @@ : 1mb-flash ( -- ) h# 10.0000 to /flash ;
0 value spi-id# +0 value jedec-id# +0 0 2value spi-id$ : spi-identify ( -- ) ab-id to spi-id# + jedec-id to jedec-id# + " Unknown" to spi-id$ spi-id# case - \ ST, Spansion, and WinBond - h# 13 of ['] common-write 1mb-flash endof - h# 34 of ['] common-write 1mb-flash - \ jedec-id h# 3425c2 = if 1mb-flash then \ MXIC 25E8035 + h# 13 of + ['] common-write 1mb-flash + " Spansion, Winbond, or ST" to spi-id$ endof - \ the SST part with its unique auto-increment address writing scheme - h# bf of ['] sst-write 1mb-flash endof - h# 14 of ['] common-write 1mb-flash - jedec-id h# 1540c8 = if 2mb-flash then \ XO-4 B1 + h# 14 of + ['] common-write 1mb-flash + jedec-id# h# 1520c2 = if 2mb-flash " MX25L1605D" to spi-id$ then + jedec-id# h# 1540c8 = if 2mb-flash " GD25Q16B" to spi-id$ then + jedec-id# h# 1540ef = if 2mb-flash " W25Q16CVSSIG" to spi-id$ then + endof + h# 25 of + ['] common-write 1mb-flash + jedec-id# h# 1525c2 = if 2mb-flash " MX25L1635E" to spi-id$ then + endof + h# 34 of + ['] common-write 1mb-flash + " Macronyx" to spi-id$ + jedec-id# h# 3425c2 = if 1mb-flash " MX25E8035" to spi-id$ then endof - h# 25 of ['] common-write 1mb-flash - jedec-id h# 1525c2 = if 2mb-flash then \ MX25L1635E + h# 35 of + ['] common-write 2mb-flash + jedec-id# h# 3525c2 = if 2mb-flash " MX25U1635E" to spi-id$ then + endof + \ the SST part with its unique auto-increment address writing scheme + h# bf of + ['] sst-write 1mb-flash + " SST" to spi-id$ endof - h# 35 of ['] common-write 2mb-flash endof \ W25Q16CV 3525c2 ( default ) ." Bad SPI FLASH ID " dup . cr ['] null-write swap endcase ( writer ) to write-spi-flash @@ -327,18 +345,10 @@ \ Display a message telling what kind of part was found
: .spi-id ( -- ) - ." SPI FLASH is " - ['] write-spi-flash behavior ['] sst-write = if - ." SST" - else - spi-id# case - h# 13 of ." type 13 - Spansion, Winbond, or ST" endof - h# 14 of ." type 14" endof - h# 25 of ." type 25 - MX25L1635E" endof - h# 34 of ." type 34 - Macronyx" endof - h# 35 of ." type 35 - 2 MB" endof - endcase - then + ." SPI FLASH is type " + spi-id# 2 .r [char] . emit jedec-id# 6 .r + ." , " spi-id$ type + ." , " /flash h# 100000 / .d ." MB." ;
: spi-flash-open ( -- )
