Author: wmb Date: Mon Jul 30 09:12:40 2012 New Revision: 3091 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3091
Log: OLPC CL4 - Working version of TIM header.
Modified: cpu/arm/olpc/cl4/olpc.bth
Modified: cpu/arm/olpc/cl4/olpc.bth ============================================================================== --- cpu/arm/olpc/cl4/olpc.bth Mon Jul 30 09:11:20 2012 (r3090) +++ cpu/arm/olpc/cl4/olpc.bth Mon Jul 30 09:12:40 2012 (r3091) @@ -41,20 +41,18 @@
fload ${BP}/cpu/arm/marvell/tim.fth
-\ Marvel Trusted Image Module image creation script for -\ XO-CL4 platform. +\ Marvell Non-Trusted Image Module image creation script for XO-CL4 platform.
-tim: 00030400 0 OLPC PXA212x -flash: SPI'10 -timh: TIMH 0 d101f000 -\ Main Processor code loaded into DRAM -image: OBMI 800 d101c000 ${BP}/cpu/arm/olpc/dummy.img -\ Secure Processor code loaded into SRAM -image: WTMI 1000 d1018000 shim.img -image: CFTH 2000 d1000000 cforth.img -reserved: - term: -end-reserved +tim: 00030400 0 THS'01 PXA212x + flash: SPI'10 + timh: TIMH 0 d101f000 + image: OBMI 2000 d1000000 cforth.img + reserved: + \ Disable USB download/init by enabling the FFUART for download + \ This works around a PHY init erratum for the B0 chip + uart: 00004646 1 + term: + end-reserved end-tim
h# 20.0000 to reserved-start
