Author: rsmith Date: 2009-10-30 21:41:00 +0100 (Fri, 30 Oct 2009) New Revision: 1452
Modified: dev/olpc/kb3700/battery.fth Log: OLPC: XO-1.5 Sync battery error codes with EC code
Modified: dev/olpc/kb3700/battery.fth =================================================================== --- dev/olpc/kb3700/battery.fth 2009-10-30 08:02:23 UTC (rev 1451) +++ dev/olpc/kb3700/battery.fth 2009-10-30 20:41:00 UTC (rev 1452) @@ -31,20 +31,31 @@ string-array bat-causes ( 00) ," " ( 01) ," Bus Stuck at Zero" -( 02) ," > 32 errors" -( 03) ," (unknown)" -( 04) ," LiFe OverVoltage" -( 05) ," LiFe OverTemp" -( 06) ," Same voltage for 4 minutes during a charge" -( 07) ," Sensor error" -( 08) ," Voltage is <=5V and charging_time is >= 20 secs while the V85_DETECT bit is off" -( 09) ," Unable to get battery ID and Battery Temp is > 52 degrees C" +( 02) ," Pack info" +( 03) ," NiMH Temp" +( 04) ," NiMH Over Voltage" +( 05) ," NiMH Over Current" +( 06) ," NiMH No voltage change during use" +( 07) ," " +( 08) ," NiMH Pre-charge fail" +( 09) ," No Battery ID" +( 0a) ," LiFe Over Voltage" +( 0b) ," LiFe Over Temp" +( 0c) ," LiFe No voltage change during use" +( 0d) ," " +( 0e) ," " +( 0f) ," " +( 10) ," ACR error" +( 11) ," NIMH 0xFF count" +( 12) ," FF count" end-string-array
: .bat-cause ( -- ) bat-cause@ bat-causes count type cr ;
+: .bat-error .bat-cause ; + string-array bat-states ," no-battery " ," charging-idle " @@ -84,8 +95,10 @@ : .bat ( -- ) bat-status@ ( stat ) ." AC:" dup h# 10 and if ." on " else ." off " then ( stat ) - ." PCB: " pcb-temp 2.d ." C "
+\ PCB temp was nver really valid and was removed in Gen 1.5 +\ ." PCB: " pcb-temp 2.d ." C " + dup h# 81 and if ." Battery: " .bat-type @@ -115,6 +128,7 @@ : watch-battery ( -- ) begin (cr .bat kill-line d# 1000 ms key? until key drop + bat-status@ 8 and if cr .bat-error then ;
\ A few commands for looking at what the EC is doing in @@ -529,7 +543,7 @@ d# 625 ( mV ) * d# 15 ( mOhm ) / ;
-: bg-V>V ( raw-value - Volts ) +: bg-V>V ( raw-value - V_in_mV ) d# 488 ( mV ) * 2* d# 100 / 5 >> ;
