Author: quozl Date: Tue Jan 10 02:45:52 2012 New Revision: 2805 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2805
Log: OLPC XO-1.75 - retry EDI interface activation when using it for tag maintenance operations, change EDI byte in to reveal an inactive state, tested on C1 SKU201, fix for #11565.
Modified: cpu/arm/olpc/ecflash.fth cpu/arm/olpc/edi.fth
Modified: cpu/arm/olpc/ecflash.fth ============================================================================== --- cpu/arm/olpc/ecflash.fth Sun Jan 8 05:29:01 2012 (r2804) +++ cpu/arm/olpc/ecflash.fth Tue Jan 10 02:45:52 2012 (r2805) @@ -39,7 +39,7 @@ : set-ec-reboot ( -- ) 1 h# f018 edi-b! ; : ?reflash-ec-flags ( adr -- ) use-edi-spi ( adr ) - spi-start ( adr ) \ avoids holding EC in reset + edi-open-active ( adr ) \ avoids holding EC in reset load-base /flash-page ec-flags-offset edi-read-flash ( adr ) dup load-base /flash-page comp ( adr different? ) if
Modified: cpu/arm/olpc/edi.fth ============================================================================== --- cpu/arm/olpc/edi.fth Sun Jan 8 05:29:01 2012 (r2804) +++ cpu/arm/olpc/edi.fth Tue Jan 10 02:45:52 2012 (r2805) @@ -26,12 +26,20 @@ ; [ifndef] edi-wait-b : edi-wait-b ( -- b ) \ Wait for and receive EC response byte - d# 10000 0 do - spi-in h# 50 = if - spi-in ( b ) - spi-cs-off ( b ) - unloop exit - then + d# 100 0 do + spi-in ( d ) + dup h# 5f <> if ( d ) + dup h# 50 = if ( d ) + drop + spi-in ( b ) + spi-cs-off ( b ) + unloop exit + then ( d ) + spi-cs-off ( d ) + h# ff = abort" EDI byte in inactive" + true abort" EDI byte in confused" + then ( d ) + drop loop spi-cs-off true abort" EDI byte in timeout" @@ -228,6 +236,10 @@ \ fast-edi-clock \ Target speed up to 16 MHz \ reset ; +: edi-open-active ( -- ) + spi-start + ['] select-flash catch if select-flash then +;
\ LICENSE_BEGIN \ Copyright (c) 2011 FirmWorks
