Author: wmb Date: Fri Sep 23 07:01:37 2011 New Revision: 2529 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2529
Log: OLPC security - added require-signatures? value for unsigned booting.
Modified: cpu/x86/pc/olpc/security.fth
Modified: cpu/x86/pc/olpc/security.fth ============================================================================== --- cpu/x86/pc/olpc/security.fth Fri Sep 23 07:00:36 2011 (r2528) +++ cpu/x86/pc/olpc/security.fth Fri Sep 23 07:01:37 2011 (r2529) @@ -603,8 +603,11 @@ 2drop false ( good? ) ;
+true value require-signatures? + \ Find a sig0N: line and check its sha256/rsa signature : sha-valid? ( data$ sig$ -- okay? ) + require-signatures? 0= if 4drop true exit then ( data$ sig$ ) next-sig-in-list$ if 2drop false exit then ( data$ rem$ sig$ ) 2nip " sha256" signature-good? ; @@ -612,6 +615,7 @@ \ Find two sig0N: lines, the first with sha256 and the second with rmd160, \ and check their signatures : fw-valid? ( data$ sig$ -- okay? ) + require-signatures? 0= if 4drop true exit then ( data$ sig$ ) 2swap 2>r ( sig$ r: data$ ) next-sig-in-list$ if 2r> 2drop false exit then ( rem$ sig$ ) 2r@ 2swap sha-valid? 0= if ( rem$ r: data$ ) @@ -737,17 +741,22 @@ \ like "runos.zip" (the normal OS, used when an valid lease is \ present) or "actos.zip" (the activation version of the OS).
+: use-run ( -- ) " run" cn-buf place ; +: use-act ( -- ) " act" cn-buf place ; : ?leased ( -- ) - " ak" find-tag if - 2drop " run" - else - rtc-rollback? if - " act" + require-signatures? if + " ak" find-tag if + 2drop use-run else - lease-valid? if " run" else " act" then + rtc-rollback? if + use-act + else + lease-valid? if use-run else use-act then + then then + else + use-run then - cn-buf place ;
: set-alternate ( -- ) @@ -1208,11 +1217,13 @@ filesystem-present? if ( list$ )
show-dot ( list$ ) - has-developer-key? if ( list$ ) - 2drop ( ) - true to security-off? - show-unlock - true exit + require-signatures? if ( list$ ) + has-developer-key? if ( list$ ) + 2drop ( ) + true to security-off? + show-unlock + true exit + then ( list$ ) then ( list$ )
load-from-device if ( list$ )
