Author: quozl Date: Fri Dec 7 06:09:54 2012 New Revision: 3480 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3480
Log: OLPC - libertas, add unused eeprom dump helper
Modified: dev/libertas.fth
Modified: dev/libertas.fth ============================================================================== --- dev/libertas.fth Fri Dec 7 06:08:04 2012 (r3479) +++ dev/libertas.fth Fri Dec 7 06:09:54 2012 (r3480) @@ -829,11 +829,26 @@ a 59 ( CMD_EEPROM_ACCESS ) prepare-cmd ACTION_GET +xw ( idx ) +xw - 4 +xw + 4 +xw \ maximum h# 10 outbuf-wait if 0 exit then respbuf >fw-data 6 + le-l@ ;
+[ifdef] notdef + : eeprom-dump + 400 0 do + i 8 .r ." : " + a 59 ( CMD_EEPROM_ACCESS ) prepare-cmd + ACTION_GET +xw \ Action + i +xw \ Offset + 10 +xw \ Byte Count + outbuf-wait if unloop exit then + respbuf >fw-data 6 + + dup 8 cdump space 8 + 8 cdump cr + 10 +loop + ; +[then] + \ ========================================================================= \ Miscellaneous control settings \ =========================================================================
