Author: wmb Date: Fri Sep 14 08:18:41 2012 New Revision: 3303 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3303
Log: OLPC ARM audio driver - device tree tweaks for instantiating the Linux audio driver from the device tree.
Modified: cpu/arm/olpc/sound.fth
Modified: cpu/arm/olpc/sound.fth ============================================================================== --- cpu/arm/olpc/sound.fth Wed Sep 12 08:06:31 2012 (r3302) +++ cpu/arm/olpc/sound.fth Fri Sep 14 08:18:41 2012 (r3303) @@ -33,32 +33,53 @@ \ DMA IRQ status and mask registers, e.g. ICU_DMA_IRQ1_STATUS
dev / +1 [if] new-device " adma" device-name - h# 800 +audio h# 100 reg - 3 encode-int 2 encode-int encode+ " mmp-mav-dma-channels" property + h# 900 +audio h# 100 reg + 5 encode-int 4 encode-int encode+ " mmp-mav-dma-channels" property " marvell,mmp-audio-dma" +compatible - current-device ( adma0-ph ) + " disabled" " status" string-property + current-device ( adma1-ph ) +finish-device + +new-device + ( adma1-ph ) encode-int " adma-node" property + " pcm" device-name + 1 0 reg + + \ This binds to the platform driver, a single point that collects + \ the Audio DMA resources + " marvell,mmp-pcm-audio" +compatible \ snd_soc_dai_link.cpu_dai_of_node + " disabled" " status" string-property + finish-device +[then]
new-device " adma" device-name - h# 900 +audio h# 100 reg - 5 encode-int 4 encode-int encode+ " mmp-mav-dma-channels" property + h# 800 +audio h# 100 reg + 3 encode-int 2 encode-int encode+ " mmp-mav-dma-channels" property " marvell,mmp-audio-dma" +compatible - current-device ( adma0-ph adma1-ph ) + current-device ( adma0-ph ) finish-device
new-device - " asram" device-name - audio-sram-pa /audio-sram reg + ( adma0-ph ) encode-int " adma-node" property + " pcm" device-name + 0 0 reg
- \ We call this the platform driver, a single point that collects + \ This binds to the platform driver, a single point that collects \ the Audio DMA resources " marvell,mmp-pcm-audio" +compatible \ snd_soc_dai_link.cpu_dai_of_node
- ( adma0-ph adma1-ph ) - encode-int rot encode-int encode+ " adma-nodes" property +finish-device + +new-device + " asram" device-name + audio-sram-pa /audio-sram reg + + " marvell,mmp-asram" +compatible finish-device
new-device @@ -66,6 +87,10 @@ h# d00 +audio h# 100 reg
" marvell,mmp-sspa-dai" +compatible +[ifdef] mmp2 " marvell,mmp3-sspa-dai" +compatible [then] +[ifdef] mmp3 " marvell,mmp3-sspa-dai" +compatible [then] + + " unused" " status" string-property
" /pmua" encode-phandle d# 20 encode-int encode+ " clocks" property d# 3 " interrupts" integer-property @@ -77,6 +102,8 @@ h# c00 +audio h# 100 reg
" /pmua" encode-phandle d# 20 encode-int encode+ " clocks" property d# 2 " interrupts" integer-property @@ -94,7 +121,9 @@ ; : start-audio-pll ( -- error? ) \ For VCXO=26 MHz, OCLK=12.2880 MHz - h# 200d.a189 h# 38 sspa! \ DIV_OCLK_MODULO=010 FRACT=00da1 ENA_DITHER=1 ICP=0 DIV_FBCCLK=01 DIV_MCLK=0 PU=1 + \ MMP2: DIV_OCLK_MODULO=010 FRACT=00da1 ENA_DITHER=1 ICP=0 DIV_FBCCLK=01 DIV_MCLK=0 PU=1 + \ MMP2: DIV_OCLK_MODULO=010 FRACT=00da1 ENA_DITHER=1 ICP=0 DIV_FBCCLK=01 DIV_MCLK=011 PU=1 + [ifdef] mmp3 h# a00d.a18d [else] h# 200d.a189 [then] h# 38 sspa! h# 0000.0801 h# 3c sspa! \ CLK_SEL=1 (AudioPLL) DIV_OCLK_PATTERN=01 d# 50 0 do h# 3c sspa@ h# 10000 and if @@ -108,7 +137,7 @@
: dly d# 10 us ;
-false value use-audio-pll? +true value use-audio-pll? : audio-clock-on ( -- error? ) my-clock-on
@@ -135,7 +164,7 @@ \ That is true on both MMP2 and MMP3 h# 20.0000 h# 1024 +mpmu io-set \ Enable 12S clock out to SSPA1
- h# 10800 h# 38 sspa! + \ h# 10800 h# 38 sspa! \ Appears unnecessary; not sure what it does
\ Bits 14:9 set the divisor from SYSCLK to BITCLK. The setting below \ is d# 8, which gives BITCLK = 1.536 MHz. That's 32x 48000, just enough @@ -709,7 +738,15 @@
0 0 " " " /" begin-package " audio-complex" device-name - " olpc,mmp-audio" +compatible +[ifdef] olpc-cl4 + " olpc,xo4-audio" +compatible +[then] +[ifdef] olpc-cl3 + " olpc,xo3-audio" +compatible +[then] +[ifdef] olpc-cl2 + " olpc,xo1.75-audio" +compatible +[then]
\ The name that was hardcoded in the Linux driver was OLPC XO-1.75 " OLPC XO" " model" string-property @@ -722,9 +759,13 @@ " MIC2" +string " Mic Jack" +string " audio-routing" property
+ " rt5631" " dai-link-name" string-property + " rt5631" " stream-name" string-property + " rt5631-hifi" " codec-dai-name" string-property + " /audio-codec" encode-phandle " codec-node" property " /audio" encode-phandle " cpu-dai-node" property - " /asram" encode-phandle " platform-node" property + " /pcm" encode-phandle " platform-node" property
\ SND_SOC_DAIFTM_xxx: \ 4000 is ..CBS_CFS - the codec is the slave for clk and FRM
