Author: wmb Date: Sat Jan 8 10:28:40 2011 New Revision: 2101 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2101
Log: SDHCI - improve support for MMC cards so eMMC on XO-1.75 A2 works.
Modified: dev/mmc/sdhci/sdhci.fth
Modified: dev/mmc/sdhci/sdhci.fth ============================================================================== --- dev/mmc/sdhci/sdhci.fth Sat Jan 8 10:23:46 2011 (r2100) +++ dev/mmc/sdhci/sdhci.fth Sat Jan 8 10:28:40 2011 (r2101) @@ -74,8 +74,16 @@ : host-high-speed ( -- ) h# 28 cb@ 4 or h# 28 cb! ; : host-low-speed ( -- ) h# 28 cb@ 4 invert and h# 28 cb! ;
-: 4-bit ( -- ) h# 28 cb@ 2 or h# 28 cb! ; -: 1-bit ( -- ) h# 28 cb@ 2 invert and h# 28 cb! ; +: 4-bit ( -- ) h# 28 cb@ h# 20 invert and 2 or h# 28 cb! ; +: 1-bit ( -- ) h# 28 cb@ h# 22 invert and h# 28 cb! ; + +: hc-supports-8-bit? ( -- flag ) + h# 28 cb@ ( old-val ) + dup h# 20 or h# 28 cb! ( old-val ) + h# 28 cb@ h# 20 and 0<> ( old-val flag ) + swap h# 28 cb! ( flag ) +; +: 8-bit ( -- ) h# 28 cb@ h# 20 or h# 28 cb! ;
\ : led-on ( -- ) h# 28 cb@ 1 or h# 28 cb! ; \ : led-off ( -- ) h# 28 cb@ 1 invert and h# 28 cb! ; @@ -428,6 +436,9 @@ dma-release scratch-buf ; +: mmc-switch ( arg -- ) \ CMD6 for MMC - no data + h# 061b 0 cmd response h# 80 and if ." MMC SWITCH_ERROR" cr then +;
: deselect-card ( -- ) 0 h# 0700 0 cmd ; \ CMD7 - with null RCA : select-card ( -- ) \ CMD7 R1b @@ -511,6 +522,34 @@ intstat-off ;
+\ The bit numbering follows the table on page 78 of the +\ SD Physical Layer Simplified Specification Version 2.00. + +\ The "8 -" accounts for the fact that the chip's response +\ registers omit the CRC and tag in bits [7:0] +: csdbit ( bit# -- b ) + 8 - + dup 3 rshift csd + c@ ( bit# byte ) + swap 7 and rshift 1 and +; +: csdbits ( high low -- bits ) + swap 0 -rot do 2* i csdbit or -1 +loop +; + +: mmc-v4? ( -- flag ) d# 125 d# 122 csdbits 4 >= ; + +\ This sends back 512 bytes in a single data block. +0 instance value ext-csd-buf + +\ Must be called with inststat-on +: get-ext-csd ( -- ) \ CMD8 R1 + d# 512 " dma-alloc" $call-parent to ext-csd-buf + ext-csd-buf d# 512 dup (dma-setup) + 0 h# 083a h# 13 cmd + 2 wait + dma-release +; + \ Decoder for the result of ACMD13 - app-get-status : sdstatbit ( bit# -- b ) d# 511 swap - ( bit#' ) @@ -540,7 +579,13 @@
\ Using this before a write-multiple command speeds up the write by \ avoiding unnecessary preservation of data that will be clobbered. -: pre-write-erase ( #blocks -- ) intstat-on app-prefix ( #blocks ) h# 171a 0 cmd ; \ ACMD23 R1 +: pre-write-erase ( #blocks -- ) + mmc? if + drop + else + intstat-on app-prefix ( #blocks ) h# 171a 0 cmd \ ACMD23 R1 + then +;
\ You might want to turn this off for data transfer, as it controls \ a resistor on one of the data lines @@ -661,7 +706,7 @@
\ SD version 2 adds CMD8. Pre-v2 cards will time out. false to timeout? send-if-cond ( ) - timeout? if h# 0030.0000 else h# 4030.0000 then to oc-mode + timeout? if h# 40ff.8000 else h# 4030.0000 then to oc-mode
wait-powered if true exit then
@@ -696,13 +741,46 @@ then ;
+: ext-csd-set ( mask index -- ) 0 -rot 1 bljoin mmc-switch ; +: ext-csd-clr ( mask index -- ) 0 -rot 2 bljoin mmc-switch ; +: ext-csd! ( value index -- ) 0 -rot 3 bljoin mmc-switch ; +: mmc-ddr-4-bit ( -- ) 5 d# 183 ext-csd! ; +: mmc-ddr-8-bit ( -- ) 6 d# 183 ext-csd! ; +: mmc-1-bit ( -- ) 0 d# 183 ext-csd! ; +: mmc-4-bit ( -- ) 1 d# 183 ext-csd! ; +: mmc-8-bit ( -- ) 2 d# 183 ext-csd! ; +: mmc-high-speed ( -- ) 1 d# 185 ext-csd! ; +: mmc-26-mhz? ( -- flag ) d# 196 ext-csd-buf + c@ 1 and 0<> ; +: mmc-52-mhz? ( -- flag ) d# 196 ext-csd-buf + c@ 2 and 0<> ; +: configure-mmc ( -- ) + mmc-v4? if + get-ext-csd \ MMC Cmd 8 - Get extended CSD + + \ Ideally, the width selection would be done by using CMD19 to test the bus + hc-supports-8-bit? if + mmc-8-bit 8-bit + else + mmc-4-bit 4-bit + then + + \ Ideally, we should set the speed class/power consumption - but the devices + \ I have don't really care, so it's hard to test. + + mmc-52-mhz? if + mmc-high-speed card-clock-50 + else + mmc-26-mhz? if + mmc-high-speed card-clock-25 + then + then + else + \ Pre-v4 MMC cards do not support SWITCH, so the only choice is 1-bit + 1-bit + then +; : configure-transfer ( -- ) mmc? if - 1-bit - \ We don't support 4-bit mode for MMC yet - - \ We don't support switching to high speed on MMC yet. - \ Doing so requires reading the EXT_CSD block + configure-mmc else 2 set-bus-width \ acmd6 - bus width 4 4-bit @@ -897,12 +975,14 @@
get-all-cids \ Cmd 2 mmc? if - h# 10000 set-rca \ Cmd 3 (MMC) - Get relative card address + h# 20000 set-rca \ Cmd 3 (MMC) - Get relative card address else get-rca \ Cmd 3 (SD) - Get relative card address then
- card-clock-25 + mmc? 0= if + card-clock-25 + then
get-csd \ Cmd 9 - Get card-specific data get-cid \ Cmd 10 - Get card ID @@ -1034,6 +1114,7 @@ : close ( -- ) open-count 1 = if scratch-buf d# 64 " dma-free" $call-parent + ext-csd-buf if ext-csd-buf d# 512 " dma-free" $call-parent then then open-count 1- 0 max to open-count ; @@ -1060,23 +1141,14 @@ r> base ! ;
-\ The bit numbering follows the table on page 78 of the -\ SD Physical Layer Simplified Specification Version 2.00. - -\ The "8 -" accounts for the fact that the chip's response -\ registers omit the CRC and tag in bits [7:0] -: csdbit ( bit# -- b ) - 8 - - dup 3 rshift csd + c@ ( bit# byte ) - swap 7 and rshift 1 and -; -: csdbits ( high low -- bits ) - swap 0 -rot do 2* i csdbit or -1 +loop -; - \ The calculation below is shown on page 81 of the \ SD Physical Layer Simplified Specification Version 2.00. : size ( -- d.bytes ) + ext-csd-buf if + ext-csd-buf d# 212 + le-l@ d# 512 um* + exit + then + d# 127 d# 126 csdbits case 0 of d# 49 d# 47 csdbits ( c_size_mult )
