Author: wmb Date: Tue Oct 30 05:28:17 2012 New Revision: 3394 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3394
Log: OLPC ARM - Turn off audio clock when closing sound driver, so that test repetitions will work correctly. This may require turning the clock back on prior to starting Linux.
Modified: cpu/arm/olpc/sound.fth
Modified: cpu/arm/olpc/sound.fth ============================================================================== --- cpu/arm/olpc/sound.fth Mon Oct 29 21:37:21 2012 (r3393) +++ cpu/arm/olpc/sound.fth Tue Oct 30 05:28:17 2012 (r3394) @@ -670,8 +670,7 @@ d# 48000 set-sample-rate ; : (close) -\ Reinstate audio-clock-off when Linux turns on its own clock -\ audio-clock-off + audio-clock-off adma-base h# 100 " map-out" $call-parent sspa-base h# 100 " map-out" $call-parent 0 to adma-base 0 to sspa-base
