Author: wmb Date: Mon Feb 27 22:46:01 2012 New Revision: 2885 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2885
Log: OLPC XO-3 - Fixed GPIO 126 MFPR setting so it can be used to enable/disable power to the USB OTG port.
Modified: cpu/arm/olpc/emmc.fth
Modified: cpu/arm/olpc/emmc.fth ============================================================================== --- cpu/arm/olpc/emmc.fth Mon Feb 27 04:04:58 2012 (r2884) +++ cpu/arm/olpc/emmc.fth Mon Feb 27 22:46:01 2012 (r2885) @@ -19,7 +19,9 @@ ; : select-emmc ( -- ) h# c1 d# 113 af! \ SD_CMD as GPIO - h# c1 d# 126 af! \ SD_DATA2 as GPIO +[ifndef] olpc-cl3 \ Leave at the initial setting for CL3 + h# c0 d# 126 af! \ SD_DATA2 as GPIO +[then] h# c0 d# 127 af! \ SD_DATA0 as GPIO h# c0 d# 130 af! \ SD_DATA3 as GPIO h# c0 d# 135 af! \ SD_DATA1 as GPIO
