Author: quozl Date: Mon Feb 18 23:47:41 2013 New Revision: 3558 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3558
Log: OLPC XO-4 - sdhci, device tree, set a non-removable attribute for internal microSD slot, #12561.
Modified: cpu/arm/olpc/cl4/sdhci.fth
Modified: cpu/arm/olpc/cl4/sdhci.fth ============================================================================== --- cpu/arm/olpc/cl4/sdhci.fth Mon Feb 18 08:31:19 2013 (r3557) +++ cpu/arm/olpc/cl4/sdhci.fth Mon Feb 18 23:47:41 2013 (r3558) @@ -41,6 +41,11 @@ " /interrupt-controller/interrupt-controller@184" encode-phandle " interrupt-parent" property d# 0 " interrupts" integer-property
+ \ The media is considered non-removable (at run-time) since the slot is + \ only accessible on the motherboard, and a heatsink must be removed to + \ access it. + 0 0 " non-removable" property + " /pmua" encode-phandle d# 27 encode-int encode+ " clocks" property " PXA-SDHCLK" " clock-names" string-property d# 40 encode-int 1 encode-int encode+ " power-delay-ms" property
