Author: wmb Date: 2009-12-11 10:31:05 +0100 (Fri, 11 Dec 2009) New Revision: 1579
Modified: cpu/x86/pc/olpc/via/factory.fth dev/olpc/kb3700/battery.fth Log: OLPC selftests - fixed booting bug introduced by 1575 and 1576.
Modified: cpu/x86/pc/olpc/via/factory.fth =================================================================== --- cpu/x86/pc/olpc/via/factory.fth 2009-12-11 07:32:02 UTC (rev 1578) +++ cpu/x86/pc/olpc/via/factory.fth 2009-12-11 09:31:05 UTC (rev 1579) @@ -25,9 +25,6 @@ 0 ( station# ) then ( station# ) to test-station - test-station 6 <> if - ['] test-station to (diagnostic-mode?) - then ;
: set-boot-device ( -- )
Modified: dev/olpc/kb3700/battery.fth =================================================================== --- dev/olpc/kb3700/battery.fth 2009-12-11 07:32:02 UTC (rev 1578) +++ dev/olpc/kb3700/battery.fth 2009-12-11 09:31:05 UTC (rev 1579) @@ -863,7 +863,8 @@
: interactive-test ( -- error? ) test-battery if true exit then - diagnostic-mode? 1 <> if \ Skip this test in SMT + " test-station" $find if execute else 2drop 0 then ( station# ) + 1 <> if \ Skip this test in SMT test-discharging if true exit then then test-charging if true exit then
